04-20-2019, 02:50 AM | #1 |
Bad straightahead-line drive
Hello everybody,
my roadster has a strange problem: the straight-line drive is not good. I renewed therefore the bearing shells on the steering wheel transmission and the tie rods. The tie is adjusted at +1/12 inch. The tires an shock-adsorbers are new. If I set the tire pressure in the front to comfortable 26 PSI, the car lurches unpleasantly up to about 35 ml/h, in more speed it rises well straight ahead. If I increase the tire pressure to hard 36 PSI, the straight-ahead is much better. Does anyone have a hint?
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
04-20-2019, 08:42 AM | #2 |
Re: Bad straightahead-line drive
Several intents may be lost in the language translation, so please forgive me, but the +1/12 inch would indicate to me that the front wheel alignment is toe-ed-out. If this is the case, with the lower tire pressures, the tires are gripping more which the extra traction is likely causing the darting or wandering. Try resetting the toe-in to an number between 1/16th to 1/8th inch and see if that corrects your issue.
04-20-2019, 09:49 AM | #3 |
Yes, set to 3mm toe-in and 241kPa (kalt) for all tires
04-20-2019, 02:52 PM | #4 |
The toe is 1/12 inch, about 2 mm tires front narrower. The air pressure is currently 38 PSI, 2.5 bar.
