11-06-2018, 10:17 AM | #21 |
Re: Brighter 6v bulbs for early fords
fortyonerag, yes, they do work with positive earth (ground).
11-06-2018, 01:55 PM | #22 |
11-06-2018, 04:07 PM | #23 |
My friend bought a Packard, it came with several "bright" bulbs for the tail/ brake lights,halogen, led in several types,none were bright, I found there was only 4 volts at the tail/ brake lights, traced the loss to the ammeter, it had rusty nuts , changed the nuts and any of the bulbs were bright ---- the moral is check what voltage you have at the bulb with the bulb on --- with no load on the wire it can show full voltage
11-06-2018, 04:31 PM | #24 |
An LED is a diode and should be directional. Worse case, reverse the wires on the socket.
Correction: This would be wrong, brain freeze!! You can NOT just reverse the wires on an LED bulb/socket. Last edited by JSeery; 11-08-2018 at 08:47 AM. |
11-06-2018, 06:33 PM | #25 |
I trying to find around a 50/20 rear brake/tail light bulb. I had bought 2 a couple of years but now need 2 more and can't remember where I bought them
They were a lot brighter than the originals. Moe |
11-06-2018, 07:59 PM | #26 |
11-06-2018, 09:50 PM | #27 |
Yep. Reversing the LED wires won't do anything on a dual function bulb cuz one wire goes to the hot brake switch, the other to the hot light switch. If hot is the wrong polarity, LEDs won't work cuz the outside of the base is always to ground, not another wire and not isolated. The LED bulb itself must be internally set up for either positive or negative ground not both. Jack e/NJ
11-06-2018, 11:32 PM | #28 | |
11-07-2018, 02:21 PM | #29 |
American Made 1154 Bulbs have Larger Filaments than the bulbs made in another country.
11-08-2018, 08:32 AM | #30 | |
11-08-2018, 09:19 AM | #31 |
what ever bulb is used paint the inside of the taillight white every little bit helps
11-08-2018, 05:02 PM | #32 |
11-25-2018, 05:56 AM | #33 |
Yes, diodes (even light emitters - LED) are supposed to be directional and won't work on +ve ground unless specifically designed for it.
11-25-2018, 06:00 AM | #34 |
The universal LEDīs have a bridge rectifier built into them allowing you to use either Pos. or Neg. Ground.
I used to gut a lightbuld socket and solder in what i needed myself...but its a lot of work. |
11-26-2018, 02:35 AM | #35 |
^^^^Thanks
11-27-2018, 04:27 PM | #36 |
There is a way of building the LED bulbs to be duel polarity using 6 diodes. But most bulbs on the market only have a resistor or crude regulator.
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
11-29-2018, 03:39 AM | #37 |
Bottom line is there are LEDS that will work with +ve earth and ones that won't. It all depends on how they are constructed.
08-30-2019, 11:01 AM | #38 | |
I have these in my 53' Merc for turn signal/brake lights and they work great. I also have plastic lenses and no issues after 5 years. No they haven't melted the lenses! Octane Lighting 675 Cochran St. Simi Valley, CA 93065 Toll Free855) 962-8263 International: (818) 932-9522 Email: [email protected] Open: 24hrs As to LED positive ground bulbs: https://www.ledlight.com/g18-s25-2_6...-polarity.aspx Go into the web site, then click on automotive, then scroll down to 6 volt positive ground - three pages of bulbs. "1154 led bulb for 6 Volt. The led bulb works for both positive ground chassis or negative ground chassis. 1154 LED bulb is a 6v led bulb. Up to 320 Lumen for brake light and up to 240 Lumen for tail light. This bulb is same as 1157 bulb that has two brightness levels or two filaments one is for the tail light and the other is for the brake light. This bulb works great for non polarity 6 volt positive or negative ground." "After installation of these led bulbs your flasher circuit may hyper flash. Please order part number 84787 which is a 6 volt positive chassis flasher will fix the fast flashing. Please see recommend items for a 6 ohm load equalizer for more information to fix the hyper flashing using load equalizer. This 6 volt led bulb works great for brake lights, tail lights and turn signals." Last edited by Merc Cruzer; 09-21-2019 at 08:37 PM. |
