06-29-2013, 12:39 PM | #1 |
Torque tube thrust washer
Can anyone tell me the thickness of the thrust washer in the torque tube - it lies behind the bearing before the speedo drive.
Mine is missing so I am wondering if I should find something that suits or carry on as before. Thanks in advance Bob |
06-29-2013, 12:50 PM | #2 |
Re: Torque tube thrust washer
It looks much the same as the end plate of the roller bearing ---I don't have one to measure in hand but to me it looks like they just used the same dies as the bearing plate, the holes match up---
06-29-2013, 01:20 PM | #3 |
06-29-2013, 08:32 PM | #4 |
Use the proper shim, not just any old washer. It has holes in it to allow some lubricant to get to the roller bearing.
06-29-2013, 10:09 PM | #5 |
I have found that sometimes you need 2 thrust washers to get the speedo gear to be centered in the opening.As long as both washers have the lube holes in them,it will be OK.
06-30-2013, 11:54 AM | #6 |
06-30-2013, 03:17 PM | #7 |
Thanks all - Kurt much appreciated.
