08-07-2019, 05:59 PM | #1 |
HELP Setting dual point distributor
Need help proper way to set points on ‘47 Merc. Please help trying to get running for big show coming up.
Thanks!! |
08-07-2019, 07:17 PM | #2 |
Re: HELP Setting dual point distributor
The proper way is to have it strobed on a machine to set dwell, advance & timing.
08-07-2019, 08:31 PM | #3 |
I guess set them both at .016 , lube the vac piston and drive it . However the proper way would be a distributor machine......
08-07-2019, 08:31 PM | #4 | |
Be sure the vacuum brake is in light contact with the breaker plate, then set the advance by ear. That is, advance the timing (move the timing adjustment down) until you start to get spark knock, or pinging, on throttle burst acceleration in second gear, then back off half a mark on the timing adjustment, and test again. |
08-07-2019, 08:38 PM | #5 |
If you don't have a bench type timer then set both sets of contacts to .014" and she will run fine. Of course other components inside the distributer should be cleaned and lubed, checked for wear etc. Regards, Kevin.
08-08-2019, 12:26 AM | #6 |
If you want to set it up yourself go to Vanpelt for details. I believe that info is from the Ford shop manuals: http://www.vanpeltsales.com/ Hope this helps since I plan to do the same soon - Bob |
08-08-2019, 01:13 PM | #7 |
Here is a link from flathead techno site that you may find helpful. How to time without a fixture by Brian.
http://www.btc-bci.com/~billben/dizzy.htm John
Welcome each day |
Thread Tools | |
Display Modes | |
