04-01-2019, 09:30 PM | #1 |
brake lining counter sink
hello questions
1. who sells counter sinks?-without buying the press 2. what depth should rivets be set? 3. does countr sink have stop on it to prevent going too far on lining? i'm surprised that there are no finds when i enter the search term " counter sink" on ford barn web site thanks |
04-01-2019, 10:07 PM | #2 |
Re: brake lining counter sink
I bought a machine that does it at an auction, it has stops that are adjustable, has arm over top to indicate hole placement, then countersink comes up from bottom ---i got it for 2$
04-02-2019, 01:03 AM | #3 |
I purchased one from the wood working section at hardware store
It worked well in my drill press |
04-02-2019, 09:43 AM | #4 |
I got the kit from mikes for $22.,if you go to a hardware store and buy a brad point drill bit they are sharp and can lift up the brake lining and put a hole all the way through the lining, definitely use a drill press, set the depth, hold down the material with one hand, look at the old lining for your depth, I think mine was 1/2 the thickness of the lining.
carry on |
04-02-2019, 10:02 PM | #5 |
Thread Tools | |
Display Modes | |
