Old 05-20-2010, 07:16 AM   #1
RJD
Default Front spring
I'm having trouble putting the front spring back on my 40 pickup. I'm using new shackles 1 1/2" long like the one's that came off. It's about an inch short of making it. Any ideas?
RJD is offline   Reply With Quote
Old 05-20-2010, 07:43 AM   #2
Kube
Kube's Avatar
Default Re: Front spring
Are you using a spring spreader? Are you putting in the same spring you removed or a replacement?
By 1 1/2" I assume you mean between centers. If so, they are correct.
Old 05-20-2010, 07:48 AM   #3
t.soseman
Are you using a spring spreader? I would guess it's like all other transverse springs where you must use a spring spreader between the eyes, or load the spring with body weight till the shackles will go in or disassemble the spring and put the shackles in and reassemble the spring. You said it was about an inch short of going together which is about correct for a spring in the unloaded state.
t.soseman is offline   Reply With Quote
Old 05-20-2010, 07:48 AM   #4
RJD
Same spring, what's a spring spreader?
Old 05-20-2010, 08:11 AM   #5
41PICUP
41PICUP's Avatar
Take the spring pack apart, install the main leaf, and then put the spring pack back together.
41PICUP is offline   Reply With Quote
Old 05-20-2010, 08:15 AM   #6
Brendan
Brendan's Avatar
that is a safer way to do it!
Brendan is offline   Reply With Quote
Old 05-20-2010, 08:27 AM   #7
Paul Selfe
Paul Selfe's Avatar
Better put a big clamp on it before you take the center bolt loose, those springs are pretty strong. Then put a piece of all-thread or steel dowel in the holes while you pull the leaves together to keep them in line. Two clamps would be better. Paul Selfe.
Paul Selfe is offline   Reply With Quote
Old 05-20-2010, 08:37 AM   #8
1936coupe
1936coupe's Avatar
i bolted spring to the chassis and jacked up under spring eyes one side at a time until it would line up with shackle bolts, did not use a spreader.
1936coupe is offline   Reply With Quote
Old 05-20-2010, 09:25 AM   #9
41PICUP
41PICUP's Avatar
2 c-clamps work just fine.............................takes a little longer but makes it easier.
Old 05-20-2010, 09:47 AM   #10
RJD
Believe it or not I had taken the spring apart as suggested.
Thanks for the help guy's
Old 05-20-2010, 10:24 AM   #11
Mick/mo
Mick/mo's Avatar
This is a spring spreader in action.
Mick/mo is offline   Reply With Quote
Old 05-20-2010, 11:46 AM   #12
Andy
A little light on the bending stress calculatons I think. I would not get near that thing. I would use floor jacks under each side of the spring. Get one side attached and come up on that side jack until the shackle is level. Come up on the other jack until the shackle can be assembled. All done with the car on stands.
On 35-48 fronts, a port a power works just fine.
Andy is offline   Reply With Quote
Old 05-20-2010, 12:39 PM   #13
Gary in Mozarks
Gary in Mozarks's Avatar
Can you explain how you use a porta power to spread the spring?
Gary in Mozarks is offline   Reply With Quote
Old 05-20-2010, 12:44 PM   #14
Ross in East Texas
Ross in East Texas's Avatar
Send a message via AIM to Ross in East Texas
I built adapters that have a wedge shaped end that fit the ends of my porta-power to go between the eye and spring to spread the spring. Then just push it out until the shackles can be put on and bolted together. This works on both the front and back springs very safely.
Ross Murphy
1939 Ford Standard Coupe
Ross in East Texas is offline   Reply With Quote
Old 05-20-2010, 01:26 PM   #15
19Fordy
19Fordy's Avatar
Smile Re: Front spring
Here's how I do it.
1. Select thread you want to save.
2.Right click "on it."
3.You will see a screen pop up: "save page as". Give the thread a name and click "save".
4.Minimize your HAMB screen and you will see the thread you saved with the name you gave it.
5. Click on that name and you will see the thread you saved.
Old 05-22-2010, 11:35 PM   #16
Brendan
Brendan's Avatar
THAT LOOKS SCARRY!!!
Old 05-23-2010, 06:34 AM   #17
PeteVS
PeteVS's Avatar
Default About using "C" clamps...
A couple of years ago, I think it was Miss Shelly posted a picture of a C clamp that had been used to clamp a spring together. It was a big clamp and it was pretty much "closed" when an event occurred. It seems that for what ever reason, a small amount of force was induced perpendicular to the axis of the threaded rod of the clamp, putting a lot of torsion on the "C" frame of the clamp. The frame twisted a little which increased the torque and everything went to hell. There's a lot of energy in a compressed spring which can do a lot of damage. Personally, I use a 3/4" Pony pipe clamp to hold the spring while I remove the center bolt. Then, I insert a piece of threaded rod and back off the rod and clamp alternately. Everything is nice and close when the clamp is "closed" and you don't have the large twisting forces. I reverse the operation to put the spring back together. If you're using a spring with reversed eyes, you'll have to use the clamp / threaded rod method because there's nothing for the typical spreader to grab onto.
Don't never get rid of nuthin!
PeteVS is offline   Reply With Quote
Old 05-24-2010, 06:25 AM   #18
Tom Overfield
Here is the porta power setup I used, worked perfectly.
Tom
Tom Overfield is offline   Reply With Quote
Thread Tools
Display Modes
