03-06-2018, 03:24 PM | #1 |
would i be better off modifying this part
On my 47 Ford coupe (which has a Merc frame) I took off the steering box mounting plate to move it back, and the frame at that point is taller then the plate by about 5/8". Is finding the Ford steering box plate a common enough of a part or would modifying be a better bet.
03-06-2018, 03:38 PM | #2 |
Re: would i be better off modifying this part
Probably quicker to modify what you have if it will work properly. Or, make a paper pattern and have one water jet cut.
03-06-2018, 03:50 PM | #3 |
sounds like I'm gonna have to break out the old welder
03-06-2018, 04:31 PM | #4 |
Won't you also need to move the front cross member back also?
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand https://www.fordbarn.com/forum/album.php?albumid=580 |
03-06-2018, 04:47 PM | #5 |
03-06-2018, 05:23 PM | #6 |
03-06-2018, 07:54 PM | #7 |
that's why i'm moving everything back. as far as the sheet metal everything fits in place
03-06-2018, 09:26 PM | #8 |
Good luck, that's a major project. Could you have shortened the frame some??
03-06-2018, 10:11 PM | #9 |
I think the frames are the same just different position for the steering box mount and cross member???
03-07-2018, 12:35 AM | #10 | |
The MAIN frame rails are different. The two rails are 4" longer on the Merc frame than the Ford rails, as can be seen in the drawings below. The picture below of a Merc frame and front axle explains a lot. Check out all of the special Merc brackets, like to relocate the wishbone ball, and to move the engine mounts rearward. Click on this link for a full thread that I did a lot of leg work in for Topher 5150. Note posts #4, 9 and 17. DD https://www.fordbarn.com/forum/showt...=mercury+frame |
03-07-2018, 08:32 AM | #11 |
i may have the steering box mount you need.
Pennsylvania has two seasons. Hershey week, and everything else https://sites.google.com/site/eastcoastwoodies/ |
03-08-2018, 01:23 AM | #12 |
Sheet metal may fit, but looks like your wheels are too far fwd in fenders.
12-02-2021, 12:02 PM | #13 |
Topher 5150. I saw from a different thread that you had a 41 sedan trunk lid for sale. If its still available, email me at [email protected] and we can discuss terms.
Nick |
12-02-2021, 01:51 PM | #14 |
