11-29-2019, 10:57 PM | #1 |
Really Cool Old & New Stuff
Radiator closed up since 1951. Old new parts. This stuff has been tucked away for a long long time...Some new shocks from Bill Stipe...
Anyone know what the item is that says 1933 on it? |
11-29-2019, 10:58 PM | #2 |
Re: Really Cool Old & New Stuff
more
11-29-2019, 11:06 PM | #3 |
Wow, nice
Pete |
11-29-2019, 11:19 PM | #4 |
Would you sell me the lock cylinder with the 2 keys...?
11-30-2019, 06:11 AM | #5 |
I'd say the item with 1933 embossed on it is part of a tool to be used to remove
and install rivets on brake linings. Peter |
11-30-2019, 08:46 AM | #6 |
11-30-2019, 09:13 AM | #7 |
11-30-2019, 07:23 PM | #8 |
As jimTN idicates, the radiator is NORS, not NOS. You could put it to good use on your roadster and hopefully have a straight fin and tube original for your coupe project.
12-03-2019, 06:37 AM | #9 |
Thats a bummer...I will put that in the roadster. I found 2 more, which i believe are for a B...I think ill leave them both where they are until the times comes...I see one more but i cant get to it...
12-04-2019, 08:34 AM | #10 |
If they are for a "B" they will not work as they "should" only have "One" "inlet" and "outlet". SO not sure what you trying to indicate by "B" but on here a "B" is 4 Cyl.
12-04-2019, 08:58 AM | #11 | |
I meant i think they are for a model "B" / 4cyl, meaning they are probably not what i need. I have another that i cant get to because i will need to move half of the earth to do so. I am hoping that the one "i cant get to" and do not have a picture of is for a V8... I have another 32' that will be bone stock. David was just saying i could use the repo in the roadster and hopefully i had another true Ford rad for the other car (coupe) that will be stock. Last edited by Ian1932; 12-04-2019 at 09:03 AM. |
