04-26-2019, 01:18 AM | #41 |
Re: Y Block Valve Springs, Rocker Arms &c
No problem and THANX! for thanking...
04-27-2019, 07:23 PM | #42 |
I can't find what diameter the rocker shaft should be? I check the 1956 Ford manual.
Thanks , Brian |
04-27-2019, 08:51 PM | #43 |
.781 just measured one of mine
11-29-2019, 09:07 PM | #44 | |
... ... sigh ... ... you gotta wonder ... I made a mistake. That PN is for an FE. You want - EAA 6598-A - Spring Washer The solid washer is - EAA 6590-A - Washer - Rocker Arm Shaft Steel - 1.26" O.D. - .81 " I.D. (So this will be the sizing - Size not given in MPC) I am sincerely sorry. I am having the old lady call the home in the morning to begin processing ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
