Old 11-15-2019, 03:41 PM   #1
reddog565
Default y-block blow by..
hi guys! I need your thoughts? I have a 272 (1956).
that I rebuilt less than a year ago. I'm running "trips".
the problem I'm having is, I'm getting a lot of blow by
from the oil filler tube! I know the engine is mechanically
healthy, as I rebuilt it. I have a pcv installed in the top
of the block. (not the valley pan). the road draft tube
has been eliminated.(blocked off). I understand, the
oil filler tube also acts as a fresh air intake. but, something
I'm not doing right, because there is too much blow by
thru the filler tube, thus fumes are getting into car..
I know all you guys are extremely sharp! so, I'm sure
someone has a fix.
thanks!!
reddog565 is offline   Reply With Quote
Old 11-15-2019, 04:21 PM   #2
KULTULZ
KULTULZ's Avatar
Post Re: y-block blow by..
I have a pcv installed in the topof the block. (not the valley pan). the road draft tube has been eliminated.(blocked off). I understand, the
oil filler tube also acts as a fresh air intake. but, something I'm not doing right, because there is too much blow by thru the filler tube, thus fumes are getting into car..
someone has a fix.
thanks!!
Can you show a photo of the PCV SYSTEM install?
If she is pumping fumes out of the filler cap, it is either non-functional and/or has extreme blow-by.
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 11-15-2019, 04:50 PM   #3
reddog565
Default Re: y-block blow by..
Sorry guys, having a difficult time uploading
A picture...
Old 11-15-2019, 05:02 PM   #4
KULTULZ
KULTULZ's Avatar
Keep trying. If you need help, yell.
- WHY IS IT ... -
Old 11-15-2019, 05:47 PM   #5
reddog565
The pcv valve is next to distributer.
Old 11-15-2019, 05:54 PM   #6
scicala
scicala's Avatar
Has the engine been having this issue ever since you installed the PCV system, or did it start later on it's own ? Even after a fresh rebuild things can happen to cause more blow by.
Sal
scicala is offline   Reply With Quote
Old 11-15-2019, 06:07 PM   #7
Daves55Sedan
Daves55Sedan's Avatar
I can't tell where your hose is connecting to in the block from that picture. What you should be trying to do is to ventilate the crankshaft.
Best way is to have openings at opposite ends of each other in relation to crankshaft. The original ideas of having the oil filler cap with an integral filter and ventilation tube/screen cannister in the lower block is good and the other being at the back of valley pan instead of the tube is okay also.
Old 11-15-2019, 06:46 PM   #8
reddog565
Sorry guys, couldn't get a better picture .as
I stated previously. The pcv valve is tapped
Into the block. It's vacuum is supplied from the
Port between ctr. And front carb. I'm wondering
If I should put the road draft tube back on it?
Such as Dave said about having ventilation
At opposite ends. Does anyone have a good
Canister and tube?
Old 11-15-2019, 07:00 PM   #9
KULTULZ
KULTULZ's Avatar
Question Re: y-block blow by..
The pcv valve is tapped Into the block. It's vacuum is supplied from the
Do you mean the PCV install is as shown below?
- WHY IS IT ... -
Old 11-15-2019, 07:13 PM   #10
reddog565
Yes kultulz. That's exactly what I have! I'm thinking the engine is not breathing properly so it's just blowing it back out of the oil filler tube?
Old 11-15-2019, 07:21 PM   #11
KULTULZ
KULTULZ's Avatar
Exclamation Re: y-block blow by..
You do not have an effective system. The valve has no baffling and will ingest spray/vapors making the system ineffective.
- WHY IS IT ... -
Old 11-15-2019, 07:55 PM   #12
miker98038
miker98038's Avatar
I had a PCV valve in the valley pan without sufficient baffling. It pick up a lot of oil, which on my set up mainly ended up in # 7&8 cylinders. But that was into the rear carb fitting on a 4 barrel. A stuck PCV valve will also produce your symptoms, to the point of blowing out a valve cover gasket in extreme cases. (Ask how I know, and the mess of oil on the exhaust is almost as bad as the heart attack when all the smoke shows up).
What engine was that PCV designed for? Did it mount vertically in the OEM application?
How much oil is the engine using, and how many miles since the rebuild?
miker98038 is offline   Reply With Quote
Old 11-16-2019, 02:28 AM   #13
reddog565
I believe the pcv valve was supposed to be
For a y block application.the engine doesn't
Use oil. There's probably a couple thousand
Miles on Rebuild.
Old 11-16-2019, 02:55 AM   #14
KULTULZ
KULTULZ's Avatar
Let me be more concise, the setup @ the carb is fine. It is the actual valve setup that is ineffective.
- WHY IS IT ... -
Old 11-16-2019, 07:21 AM   #15
reddog565
So, what needs to be done to
Fix this problem?
Old 11-16-2019, 07:36 AM   #16
darrell
what kind of rings did you use.i had trouble with a set of moly rings.the first time i saw a pcv in that spot i wondered.the dist, spinning in the cam gear is going to throw a lot of oil around.most of the top end oil is running down there.
darrell is offline   Reply With Quote
Old 11-16-2019, 09:26 AM   #17
KULTULZ
KULTULZ's Avatar
Thumbs up Re: y-block blow by..
Originally Posted by darrell View Post
...the first time i saw a pcv in that spot i wondered.the dist, spinning in the cam gear is going to throw a lot of oil around.most of the top end oil is running down there.
Exactly! Good point ...
- WHY IS IT ... -
Old 11-16-2019, 09:57 AM   #18
reddog565
Thanks for hanging with me guys!
This is an issue that needs to be resolved,
I can't breathe those toxic fumes... Can't
remember what type of rings are used?
Pcv valve#255.
Old 11-16-2019, 10:14 AM   #19
KULTULZ
KULTULZ's Avatar
Read this thread - https://www.fordbarn.com/forum/showt...19#post1821719
Don't worry yourself as it can be solved. BTW- Where did you get the info to set up the valve location?
- WHY IS IT ... -
Old 11-16-2019, 10:37 AM   #20
reddog565
I acquired the motor that way...
