10-18-2019, 10:59 AM | #1 |
Early V8 axle under Model A front end
First let me begin stating that this topic has been presented many times but I need assistance. I have 1935 front axle that I would like to install under a 1931 A and retain mechanical brakes. It is my understanding that 1932-34 spring perches are required to complete swap. Bob Drake has B-3032 perches for 1932's, I called their tech assistance and explained Plan A. I was informed that B-3032 would not work for my situation. Don't remember any "why nots". Any assistance will be greatly appreciated.
ag32milner |
10-18-2019, 11:54 AM | #2 |
Re: Early V8 axle under Model A front end
Model A through '34 had the same center-to-center spring-perch distance, 1935 - '48 that distance was wider, so the spring perch on your '35 would be closer to the brake backing plate. You would also need a longer spring, and your shocks wouldn't line up properly. '32-'34 would be an easier route to take.
10-18-2019, 03:53 PM | #3 |
35 creates problems as stated, add modifying the wishbone to the list.
Basically, it’s not a direct swap. If you use a 32-34 axle, I suggest using the spindles as well. There’s not much room for the tie rod to clear the front crossmember and pan if you keep the model A spindles. Although they can work, torching and bending the steering arms has to be just right. Just my opinion. |
10-19-2019, 10:37 AM | #4 |
The distance from the top of the axle I-beam to the bottom at the perch points also changed which would affect the fit up of the wishbone. Model A axles are still out there. I've purchased a lot of them looking for straighter ones than ones I had. It would be a lot easier to just replace it.
10-19-2019, 07:14 PM | #5 |
The V8 axle will drop your front end a bit if that is what you are looking for. Reverse the spring eyes for more drop.
You will need a 1/4" thick spacer for the wishbone as the V8 axle is thinner. Put the spacer on the bottom of the axle. Otherwise the tie rod will rub on the wishbone. I found 1/4" fender washers that work nicely after having the center hole enlarged.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? Last edited by Chris Haynes; 10-20-2019 at 12:19 AM. |
10-20-2019, 03:04 AM | #6 | |
Much of this is incorrect, in that 1935-36 axles are identical to 1933-34. The method of spring mounting differs between those years but there is no difference in the axles themselves. 1932 axles also share the same dimensions for wishbone attaching and kingpin holes but were made heavier overall. All 1932-36 axles are 1/4" smaller at the wishbone attaching point and a spacer is required here, as previously mentioned, if these axles are to be used with Model A wishbones attached. |
10-20-2019, 05:09 AM | #7 |
Don’t know how I forgot this.. too much to remember
33-36 axles are all the same as Randy states. I’d still suggest using 32 spindles over the model A. One more thing, you’re going to need a bushing for the 32 spring perches to use with the Model A shackle |
10-20-2019, 11:31 AM | #8 |
I used the "A" spring perches as the later ones have no provision for shock mounting. Here you can see that I removed the mount for the mechanical brakes.
Notice the 1/4" spacer between the bottom of the Axle and the Wishbone.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? Last edited by Chris Haynes; 10-20-2019 at 11:47 AM. |
10-20-2019, 11:46 AM | #9 |
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
10-20-2019, 11:51 AM | #10 |
Randy and Walls could be right, I don't think so but could be wrong. Best to measure before taking things apart, to be sure. '32 axles came in 2 styles, heavy duty and standard. Not sure but think the heavy duty was mostly in trucks. The difference is obvious when looking at them.
10-20-2019, 12:41 PM | #11 |
Chris Haynes: How did you get your tie rod to cross over above the wishbone? On a Model-A axle mounted with '37-'41 spindles the tie rod will pass below the wishbone. Did you have to bend the steering arms upward? Thanks!
