03-18-2018, 08:42 PM | #1 |
Broken door latch on 40 Tudor
I have window frame screws out upholstery loose, window crank, door latch handle off, arm rest is still hooked on, can't budge it how does window frame come loose? Thanks for some help. Gene
03-18-2018, 09:24 PM | #2 |
Re: Broken door latch on 40 Tudor
If you mean the garnish molding, once the screws are removed, it should come off with a good jerk.
03-19-2018, 08:04 AM | #3 |
The top part came loose but the lower half is tight vent window and all. Gene
03-19-2018, 08:27 AM | #4 |
03-19-2018, 08:28 AM | #5 |
