Old 06-26-2013, 02:57 PM   #1
stouchton
stouchton's Avatar
Default A Toe-out question.....
Is there any logical reason someone would toe-out a Model A 1/4"?
I corrected it to be 1/8" toe-in but got to wondering if someone had a reason to do this. (I have not road tested the car yet since adjusting the toe).
The car did handle a little squirrely toed out, but not too bad. She does have a lot of slop in a kingpin and I got to wondering if this was someone's trick to compensate for that play.
Appreciate any thoughts.
stouchton is offline   Reply With Quote
Old 06-26-2013, 03:16 PM   #2
700rpm
700rpm's Avatar
Default Re: A Toe-out question.....
Correct toe-in is about 1/32-1/16th inch. Toe-out will cause premature tire wear and bad handling.
Ray Horton, Beaver Chapter, MAFCA, Portland, OR
Old 06-26-2013, 03:25 PM   #3
whirnot
whirnot's Avatar
Maybe for a more exciting ride?
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 06-26-2013, 03:42 PM   #4
jkeesey
jkeesey's Avatar
The only logical reason is they didnt know any better. I bought a Jeep for my wife and the toe was 1 1/4" out. You want to talk about an exciting ride.
jkeesey is offline   Reply With Quote
Old 06-26-2013, 03:55 PM   #5
stouchton
stouchton's Avatar
Thanks - it did make it interesting hitting bumps. Exciting is a good word - just never sure which way she was going to try and go next
Old 06-26-2013, 03:58 PM   #6
ctvpa
ctvpa's Avatar
I have 2 model a's. One I purchased as a driver while I did a ground up on my other. I just bought an antique wheel alignment tool. While I was setting the toe on the restoration, I put the tool on the driver, I was almost 1/2 inch toe out. No issues driving, handles great, turns on a dime; no tire wear.
ctvpa is offline   Reply With Quote
Old 06-26-2013, 04:05 PM   #7
Brian T
Brian T's Avatar
You will need to take of any worn axle and steering linkage parts before adjusting toe in, toe in is the very last adjustment done to any front end.
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 06-26-2013, 04:53 PM   #8
CarlG
CarlG's Avatar
Mine was set at 3/4" toe-in. Wiped out the front tires in about 1500 miles.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 06-27-2013, 04:38 PM   #9
stouchton
stouchton's Avatar
I'm with you Brian. I need to drive the car to a couple family events and a local show, then I can pull the front spindles to put in new king pins and bushings.
Adjusted the toe in just to make it a little more stable for now, but the king pin slop will still be with me.
