08-28-2019, 02:11 PM | #1 |
Should a door handle be lubricated?
I am replacing the door latch and locking handle on my 1929 Coupe. Would it be a good idea to lubricate the handle where it turns, or is that just asking for trouble down the road. It I saw a post where the latch components and springs were greased, but wondered about the handle shaft.
Note: now that I have the repop handle, I can see why many of them need to be filed down at the square end to fit an old latch. Fortunately, this handle fits perfectly in the new latch without any filing. Next job is to install it. |
08-28-2019, 02:37 PM | #2 |
Re: Should a door handle be lubricated?
Lubrication yes. An general purpose grease should be smeared on all moving surfaces before installation.
08-28-2019, 10:36 PM | #3 |
I agree, and you may have seen my pictures of all the red grease on the parts.
On the exposed latch part you want to use Door Ease, which is bee's wax, same as a toilet ring. |
08-29-2019, 10:30 AM | #4 |
Another alternative is a dry lube with molybdenum disulfide like Moly Coat spray. There is no oil or soap to worry about and dirt doesn't stick to it. |
