10-25-2013, 02:05 AM | #1 |
Chassis Engineering Sway Bar
Has anyone used one of their sway bar kits on a '35-'40 stock front end? Their kit shows the vertical rods are attached to a small plate on the bottom of the axle pin. Are the stock pins long enough to accommodate the additional plate or do you need to replace the stock pins with a longer one?
Thanks Tom |
10-25-2013, 05:11 AM | #2 |
Re: Chassis Engineering Sway Bar
I cant see that plate as being very think should be fine. You can try emailing them.. I did.. About sending one to Australia.. never had a reply. mmm?
10-25-2013, 06:43 AM | #3 |
I'll tell you this, I bought one from them for my MII and it said right in the paper work that it was not guaranteed to fit. I had to do a lot to make it work but I have never been happy with it. I'm not saying they are bad or good, I hope I haven't confused you any, Sorry
10-25-2013, 07:12 AM | #4 |
The plates are approximately 1/16" thick, and a cup is stamped in it so that it fits into the wishbone clevis and the stock castle nut can be used.
Cory Taulbert |
10-25-2013, 08:59 AM | #5 |
Sometimes the stock axle pin will be long enough and sometimes you cannot insert the cotter key and resort to Loc-tite. Sometimes you need to shim the frame mounting brackets downward to clear the frame brackets that mount the radiator. I've installed 4 of them and each one was not a direct bolt-on fit. They do work good once installed. I prefer CE stuff to others and most aftermarket stuff never fits perfectly.
10-25-2013, 09:42 AM | #6 |
10-25-2013, 07:55 PM | #7 |
Has anyone used the sway bar from drake for the 36 ford front,looks about the same as CE
DON P |
10-25-2013, 08:28 PM | #8 |
Drake sells CE parts. The bar in the catalog is a CE bar.
10-26-2013, 10:57 AM | #9 |
I have both front and rear sway bars on my 37. they both came with detailed instructions, It was a direct bolt on minus a few holes I had to drill. one of the best handling improvements I ever made!
10-26-2013, 11:09 AM | #10 | |
