10-27-2018, 08:27 PM | #1 |
cam gear thread help Q...
Threads on cam mashed up a bit. need to clean them up. This is a B four cyl cam. It looks to be approx. 1" diameter and maybe 16 tpi. Are all cam threads same (pitch/diam) ? Anyone ever have to repair such threads ? Any helpful tips on what is needed to correct damaged cam threads ? I'm thinking that minimally , a die is needed ?
10-28-2018, 08:50 AM | #2 |
Re: cam gear thread help Q...
Come on Hardtimes, post on the A site if you haven't already .
Paul in CT |
10-28-2018, 12:53 PM | #3 | |
Thanks for your input. Well, I'm just getting back into 'active duty' ! AOL for repairs...ha ! Been to hell and back since last march...with health problems..cancer stuff. Doing much better due to modern techniques/advances. Was thinking of youse guys the whole time ! Got a new project in mind (still 4 banger) and am still amazed at all the hobby resources available. I've never read where anyone has addressed this damaged cam thread subject, over on the A site. Thought that I'd try here first then. What I really need is the DIE size of A/B cam threads !! Or some tip/trick for repairing these threads otherwise. |
10-28-2018, 01:36 PM | #4 |
If it is not mashed much, a thread file works ok.
If it is mashed bad, you about have to fix them in a lathe. |
10-28-2018, 04:38 PM | #5 | |
Thanks for your input and information ! I think of you every time that I start up that warmed up B and hear your cam sing ! You do good cam work for sure. I've already looked up thread file and this looks like the 'tip' that I needed. |
