Old 05-21-2015, 09:44 PM   #1
Mitch//pa
Default Model A on lift
Old 05-21-2015, 10:24 PM   #2
700rpm
700rpm's Avatar
Default Re: Model A on lift
Great shot. Look at all those neat tools. Where are they now? Do you know where this was taken?
Ray Horton, Portland, OR
Old 05-21-2015, 10:26 PM   #3
holdover
when I was a teenager in the early 60s worked off a rail lift just like that at Mortimer Bros garage in Huntington NY. Had many an A and T on that lift doing oil changes. Would like to have those period correct tools!
holdover is offline   Reply With Quote
Old 05-21-2015, 10:52 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
I haven't seen a rail hoist like that since the 60's.
The two bars with the dip in the center, just under the tools, must be used to support the driveshaft during work, or maybe to hook an oil bucket during the oil change. Would that be right?
Old 05-22-2015, 06:19 AM   #5
Big hammer
Originally Posted by Mitch//pa View Post
Oh no and supported by the axles
Old 05-22-2015, 07:25 AM   #6
ericr
ericr's Avatar
not to sound macabre, but does anyone know if these old lifts ever failed? I've always been uneasy getting under a car supported by jack stands and now I read on the Barn that members feel the sheet metal-type of stands are junk etc.
hardly a day goes by when we don't read about some kind of product recall...I think most of them emanate from overseas production in the modern era.
ericr is offline   Reply With Quote
Old 05-22-2015, 07:34 AM   #7
mshmodela
mshmodela's Avatar
I would guess even these old time lifts were designed with very high duty cycles and some kind of fail safe mechanism much like an elevator in the event there was a loss of hydraulic pressure...
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 05-22-2015, 07:43 AM   #8
billwill
There was a post that came down on back of hyd.cyl. to hold the lift for safty
billwill is offline   Reply With Quote
Old 05-22-2015, 07:54 AM   #9
Dollar Bill
Dollar Bill's Avatar
I remember those - It had a lever that toggled into place when the lift was all the way up. You pushed the lever in with your foot just before lowering the car.
It also prevented the lift from rotating like a merry go round.
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
Old 05-22-2015, 08:22 AM   #10
Tom Wesenberg
I used to work under a hoist where I could spin the car all the way around once the wheels were off the ground. I don't recall if it had any safety backup, but most of the hoists I worked under had the steel pipe with the safety toggle.
Old 05-22-2015, 08:28 AM   #11
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Actually, this picture originated with Brad Minners back when I was building a 'Tool Wall' here at the shop. Brad said this was taken at a dealership named Plastman in Belgium. Click HERE to view the original post that shows even more tools.
BTW, I always thought it was ironic that there was a water hose ( ...to wash the floor?? ) when it had a wooden plank floor. Also, when you study Brad's photo of the lift, you will notice there are special brackets attached to the rails that are supporting both axles.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 05-22-2015, 08:46 AM   #12
Mitch//pa
thanks Brent for that info... someone sent this to me recently so i had no idea where it was taken from..
i found looking at the pic very interesting and figured others would enjoy it
Old 05-22-2015, 10:20 AM   #13
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
HEY, KID,
I "thought" you put in a modern hoist at home??? Chief's Conoco Fillin' Station, in our small Oklahoma town had the FIRST hydraulic lift in town & we had the FIRST FAST Battery Charger in town! The hoist had a swing down safety post, like some of you described. I don't remember how big a compressor we had to put in??? GOD, I'm gettin' OOOOLD!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 05-22-2015, 10:53 AM   #14
holdover
"you will notice there are special brackets attached to the rails that are supporting both axles."
The lift at Mortimers that I used had different "sliders" that you could use to fit different vehicles all the way into the 60's. They had a piece of 1/2" round stock about 30" long attached to them so you could side them on the rails into the correct position without getting under the vehicle There was two 2X12 boards laid on the ground to give newer cars extra clrnc. over the rails which were about 5" high. The rails were too close together to do auto trans removals, but was OK for manuals and doing rear end work on newer vehicles and great for oil changes. The post always seemed to be in the way and you had to "balance the vehicle " to avoid too much weight at either end. In the late 60s the rails were removed and a spyder attachment was put on the post to accommodate modern vehicles. The safety was as mentioned, a pipe about 2 1/2" in dia that had a toggle that flipped out when at full height. The lift used air over hyd. to operate. It was a lot better than working on your back. I used this lift for years without any safety issues.
Old 05-22-2015, 11:46 AM   #15
BILL WILLIAMSON
MOST safety issues are OPERATOR ERRORS! READ THE INSTRUCTION BOOK!
Bill W.
Old 05-22-2015, 12:29 PM   #16
FL&WVMIKE
FL&WVMIKE's Avatar
I bought my house, in Spencer, WV, because a large garage came with it. I found out, later, that it had been a country Massey Ferguson dealership. Any way, it has the cylinder, etc. of a lift. It has no rails, platform, etc. with it, so I was never able to use it. It still has the toggle, up - down switch, to regulate the air/oil pressure.
I had an oldtimer, who used to install these, tell me, "Never start it up, unless you are sure it is full of fluid. If the air gets compressed, without oil, it can build up high enough to blow the cylinder, through the roof, when it breaks loose."
I guess that I could let this go, if anyone was interested.
Thank you,
MIKE (mikeburch)
FL&WVMIKE is offline   Reply With Quote
Old 05-22-2015, 05:04 PM   #17
mshmodela
mshmodela's Avatar
Great photographs!
-Mike
Cleveland, Ohio
Old 05-22-2015, 05:57 PM   #18
Keith True
Keith True's Avatar
There is one of those lifts still in use about 20 miles from me.It was a Ford garage,on a state highway that was bypassed in the late 30's,so it became a back road.The garage burned during the war though.The fellow that bought it after the war built another garage on the foundation,and the lift is still there.He had a VW junkyard in the 60's and 70's,that lift worked great on VW's.I went by a couple of nights ago on a motorcycle,it was about 11 PM,the garage door was open and the lift was about halfway up.I could see it pretty clearly in the moonlight.He's another one of us that leaves his garage door open at night to take the cool air in.
Keith True is offline   Reply With Quote
Old 05-22-2015, 08:45 PM   #19
My1930ModelA
Brent is right on the car being supported by the axles. Notice the car is at normal ride height and the suspension is not extended like it would be if it was lifted by the frame.
My1930ModelA is offline   Reply With Quote
Old 05-23-2015, 12:10 AM   #20
CarlG
CarlG's Avatar
Can't see picture(s)
OK, now I can
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Thread Tools
Display Modes
