Old 05-23-2015, 01:44 PM   #21
MikeK
MikeK's Avatar
Default Re: shimming engine bearings
If you are doing this with the engine in place did you use a jack to exert upward pressure at each individual bearing when taking your plastigauge measurements? That crank can flex a few thou and give some strange readings if you do not forcibly push it up against the block babbitt while measuring from 'down under'.
MikeK is offline   Reply With Quote
Old 05-23-2015, 08:22 PM   #22
My1930ModelA
Mike, that makes perfect sense, an no, I didn't do this or even think of this when I adjusted mine. Would have been easy to do too as I have a 2 post lift and tripod in my shop. Thanks for the tip! This is my first Model A.
Mark
My1930ModelA is offline   Reply With Quote
Old 05-29-2015, 11:15 PM   #23
norcalal
I put back some shims after the crankshaft seemed to turn too tight. Was a bit nervous, but ran the engine at a fast idle for 30 minutes, and think I'll be OK. Any thoughts? Thanks for your replies!
norcalal is offline   Reply With Quote
Old 05-30-2015, 12:56 AM   #24
Mike V. Florida
Mike V. Florida's Avatar
I use the aluminum foil method.
