Old 05-20-2022, 09:09 AM   #1
flathead48
Default Spring bushings
I want to replace the spring bushings in my 48 car, itís been 25 years or so and I imagine there has been a lot of changes in the part. Suggestion for the best would be appreciated.
Thanks, Rick
flathead48 is offline   Reply With Quote
Old 05-20-2022, 10:09 AM   #2
19Fordy
19Fordy's Avatar
Default Re: Spring bushings
Check out CW MOSS;
https://cwmoss.com/search?q=spring+bushings
Old 05-20-2022, 10:31 AM   #3
flathead48
Will do thanks 19Forty
Old 05-20-2022, 12:27 PM   #4
Andy
Do not just install them in any orientation. They should be installed at the working angle.
Andy is offline   Reply With Quote
Old 05-20-2022, 02:28 PM   #5
19Fordy
19Fordy's Avatar
Andy is correct. 45 degrees is the desired angle. The photo below is a 40 Ford reversed eye spring with shackles at 45 degrees.
Old 05-20-2022, 08:23 PM   #6
Pete
Pete's Avatar
If you use a Delrin bushing kit, they do not require any special tools to install and will last forever.
Old 05-20-2022, 10:15 PM   #7
fordor41
fordor41's Avatar
...or moly impregnated nylon 6/6 will also last forever
fordor41 is offline   Reply With Quote
Old 05-20-2022, 10:20 PM   #8
Pete
Pete's Avatar
Yup.
Old 05-21-2022, 06:09 AM   #9
flathead48
Thanks guys for all the feed back , does any one know where to get ones mentioned in post 7 thanks again to all here who offered their help.
Rick
Old 05-21-2022, 09:48 AM   #10
Bob C
McMaster_Carr. https://www.mcmaster.com/nylon-6/wea...t-nylon-tubes/
Bob C is online now   Reply With Quote
Old 05-21-2022, 09:49 AM   #11
flathead48
Thanks Bob
Old 05-21-2022, 10:53 AM   #12
19Fordy
19Fordy's Avatar
If you have a lathe, you can make your own out of brass. However, DELRIN is less expensive and will work great.These homemade shackles and bushings are are 50 years old.
Old 05-21-2022, 10:57 AM   #13
flathead48
Thanks 19forty, donít have a lath so I will have find them already made
Old 05-21-2022, 11:10 AM   #14
40cpe
40cpe's Avatar
I tried a few "plastic" bushings. I can't tell one from the other, but they all squeaked. I finally went to impregnated bronze flanged bushing or flanged bearing like 19forty made. Available in different sizes from your bearing store.
Old 05-21-2022, 04:22 PM   #15
Pete
Pete's Avatar
Urathane will squeak.
Delrin won't.
Like any bearing, it helps life if you lube them once in awhile also.
Old 05-21-2022, 05:51 PM   #16
40cpe
40cpe's Avatar
Delrin won't.
Thank you Pete.
Old 05-22-2022, 09:51 PM   #17
fordor41
fordor41's Avatar
McMaster-Carr supply- oil inbedded flanged nylon bushings
Old 05-23-2022, 05:09 AM   #18
flathead48
Thanks to all for advice and assistance
Old 05-23-2022, 06:12 AM   #19
aussie merc
aussie merc's Avatar
3rd gen sell both original and modern style show car original daily or regular driver defiantly modern like most things its your choice
aussie merc is offline   Reply With Quote
