11-12-2016, 02:03 PM | #1 |
Carbs and paint...
I am aware of some of the model airplane paints that were always used. They just are no available anymore.
Doing a basic search for fuel proof paint I found this brand: VHT Paint It is available through a number of retailers locally to everyone. Which brings me to the question of which type of paint? Gloss, Satin or Flat? I have to go look it up still, but any input would be good. I need to paint up a carb or 2. Thanks! |
11-12-2016, 03:11 PM | #2 |
Re: Carbs and paint...
I would go with flat. I've seen some unused original carbs and there was no sheen.
11-12-2016, 03:59 PM | #3 |
Originally Zenith carbs had a dull black surface. Not glossy.
11-12-2016, 04:04 PM | #4 | |
I used it on my Zenith 2 and I like how it looks.
Good enough.. Isn't. |
11-13-2016, 01:01 AM | #5 |
Look up full size aircraft suppliers to find dope. the gloss can be cut by adding talcum powder. it's about 22.00 a quart.
11-13-2016, 01:42 AM | #6 |
Epoxy is not desirable, nor is high temperature a need for a Zenith. What is important for carburetors is fuel resistance. http://www.vhtpaint.com/motorsport/vht-black-oxide-case-paint
Try Ford Garage Search |
11-13-2016, 10:34 AM | #7 |
We all have our choices! Here's what I use when rebuilding carbs,available at Hobby Stores and Amazon.
www.whidbeymodelaclub.com |
11-13-2016, 11:35 AM | #8 |
I use this easy to get lacquer paint which has held up real well ...it resists fuel also and is recommended on snyders web site for doing carbs...
11-13-2016, 01:10 PM | #9 | |
http://www.activepowersports.com/top...rMXhoC16zw_wcB
11-13-2016, 06:35 PM | #10 |
Gary, thanks for the link. I just ordered 5 cans from them. I hope that they indeed do have it in stock. The paint is bullet proof when it comes to gasoline. The carburetor paint from Snyders looks real nice and resists gasoline a little bit but is definitely not fuel proof.
Dave / Lincoln Nebraska |
11-13-2016, 10:19 PM | #11 |
Like Vince and many of you I have used the top flite fuel proof paint wit very good results, like Vince I have tried to find it in black and have been unsuccessful... However, short term till it comes available I purchased it in satin clear ( I believe also discontinued ) and the gloss clear.
I coated with the automotive dupli color black with ceramic and then too coated with the top flite clear . I have had good results so far I will try the VHT above and see how it does. I concur that it is a dilemma right now but hopefully we can get a good solution soon. Please continue to post with results . Larry Shepard |
11-14-2016, 06:42 PM | #12 |
Vince and Kevin..
You can still buy dope here,.... http://brodak.com/finishing-products...odak-dope.html Dudley |
Thread Tools | |
Display Modes | |
