Old 10-02-2013, 10:07 AM   #1
pistonburner
Default engine cutting out
Hey gys i have a 41 flattie that cuts out under just when it starts to pull good, when it is sitting you grab the throttel and almost but not quite half way it starts cutting out. I have replaced the coil even put a divorced coil on it changed the pionts changed the plugs checked all wiring from switch down to coil. engine has around 900 miles on it has fresh fuel good compression and good fuel presseure. I have done everything i know to not that i know everthing. HELP
NEVER GIVE UP
pistonburner is offline   Reply With Quote
Old 10-02-2013, 01:06 PM   #2
flatford8
flatford8's Avatar
Default Re: engine cutting out
Check the fuel filter? I just had a similar problem with my '50........Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 10-02-2013, 02:52 PM   #3
FlatheadTed
FlatheadTed's Avatar
Strip down the carb and blow out all the holes with at least 100 PSI
http://www.flatheadted.com
Disclaimer ,Copy right all rights reserved Posting in good faith for the benefit of the public ,
Cannot be used for litigation,
Old 10-02-2013, 05:17 PM   #4
pistonburner
well I changed the carb for a new one and cleaned the other one...no change
NEVER GIVE UP
Old 10-02-2013, 05:46 PM   #5
FlatheadTed
See if the spark goes to yellow /weak at the half rev limit, pull a plug wire hold it against the head nut ,or shove a screwdriver up the lead end
Old 10-02-2013, 06:01 PM   #6
Old Henry
Old Henry's Avatar
Do you have a modern fuel filter that might be plugged up?
"It is good to have an end to journey toward; but it is the journey that matters, in the end. *Ursula K. Le Guin in The Left Hand of Darkness
Old 10-02-2013, 07:53 PM   #7
pistonburner
no fuel filter
NEVER GIVE UP
Old 10-02-2013, 09:35 PM   #8
Stewart
Had a simular problem with a 1950 (other make) found there was rust flakes in the fuel tank that collect around the outlet. would stop an the street and restart after the rust pieces settled away from the outlet. Cleaned and coated the inside of the tank, problem solved.
Stewart is offline   Reply With Quote
Thread Tools
Display Modes
