Old 02-19-2019, 03:43 PM   #1
Heard
Heard's Avatar
Default What steering box is this?
Can someone verify what year box this is? I thought it was a '40 but now that I'm looking for some wiring stuff, I don't think it is. Thanks!!
Do I look like I have a plan B?
Heard is offline   Reply With Quote
Old 02-19-2019, 04:11 PM   #2
cas3
Default Re: What steering box is this?
39 last year of the switch at the bottom i believe
Old 02-19-2019, 04:24 PM   #3
Brian
Brian's Avatar
Yes, 37-39
Old 02-19-2019, 05:48 PM   #4
Juergen
Were you literally looking only at the gearbox or all of its accessories? The same gearbox was used from 1937 to 1948. The switch control on the bottom was for 37-39 as mentioned earlier. The steering arm was the same from 37 to I think 41 but later years had a different arm,
Juergen is offline   Reply With Quote
Old 02-19-2019, 06:03 PM   #5
Heard
Heard's Avatar
Well, that is good to know. I was actually trying to figure out what switch plate and harness to buy. I bought this box several years ago and am just now getting around to getting some wiring done on my '35 pickup. I had it in my notes it was a '40 but obviously, the connection is not.
Old 02-19-2019, 08:51 PM   #6
JSeery
JSeery's Avatar
Does the column have the switch on it?
Old 02-19-2019, 09:35 PM   #7
skidmarks
skidmarks's Avatar
The bottom plate, if you plan to use the headlight switch on the column shown you need to use a 37 to 39 plate. The 40 and later lower plate has a smaller diameter tube that the headlight rod wont fit through. I'm saying this because you mentioned that you thought it was a 40 box.
skidmarks is offline   Reply With Quote
Old 02-20-2019, 07:46 AM   #8
Heard
Heard's Avatar
The headlight switch is the typical center of the column/center of the steering wheel arrangement with the long rod.
Old 02-20-2019, 08:28 AM   #9
JSeery
JSeery's Avatar
Should be able to wire it like a 39 then and use the floor dimmer switch. With the correct parts you should be able to wire it like the original 35.
Old 02-20-2019, 11:06 AM   #10
Heard
Heard's Avatar
Thanks for the help guys! Much appreciated!
