06-26-2020, 05:08 PM | #1 |
O/T paint can smoker question
I'm building a 1 gallon paint can smoker from some parts I had on hand, it doesn't seem to be putting out much smoke(using baby oil on the wick). My question is about the Nichome wire, I have about 28 turns of 20ga. wire wrapped around the wick reading about 5-6 ohms, does that seem right?
06-26-2020, 06:49 PM | #2 |
Re: O/T paint can smoker question
Well, if you're using a 6v, it's only about 6 watts---night light power
12v would be about 24 watts---should start smoking. 110v, 2000 watts. Really smoking & blowing fuses. 8^) Jack E/NJ |
06-26-2020, 07:44 PM | #3 |
Powered by a spare 12 volt car battery.
06-26-2020, 07:55 PM | #4 |
What is the use of this thing? If it is for something edible, I sure hope you are using a new unused paint can. There are some pretty deadly chemicals in automotive paint these days that due to their volatility, would vaporize quite easily.
06-26-2020, 08:06 PM | #5 |
What is a "smoker"
06-26-2020, 10:45 PM | #6 |
06-26-2020, 10:55 PM | #7 | |
Yeah, I always questioned beer can chicken. Not sure I would want to bake a chicken with a aluminum beer can with painted graphics and an inside plastic liner. But I guess it tastes amazing. Not my thing. One thing I miss being up north is not going to the southside to get some amazing bbq off someones front yard. Last edited by Tinker; 06-26-2020 at 11:01 PM. |
06-26-2020, 11:43 PM | #8 |
Modern cars can be tested with a vacuum gauge.
06-27-2020, 11:27 AM | #9 |
>>>12 volt car battery.>>>
4 ohms should do it --- or maybe over-do it. Use a small alligator clip to test at different points along the nichrome. Jack E/NJ |
06-27-2020, 11:44 AM | #10 |
But, while you can see smoke, you can't see vacuum! If you have a leak in the evap system, injecting smoke will pinpoint the leak. Whereas if you merely watch a vacuum gauge to see if it drops you still have no idea where the leak is. Plus, if you're hunting an exhaust leak it's pretty hard to pull a vacuum on the exhaust system! But if you inject smoke into the tailpipe any leaks soon become obvious.
06-28-2020, 11:01 AM | #11 |
Ordinary vacuum gauge is not sensitive enough for evap work, they work in inches of mercury, for evap work you need a gauge that works in inches of water, a gauge is more used to confirm the problem, and the repair, smoke is good for finding the problem
06-28-2020, 08:26 PM | #12 | |
Thanks, interesting idea. |
06-29-2020, 07:37 AM | #13 |
Got it working, unwound and cut off some of the Nichome wire and got it down under 3 ohms.
06-29-2020, 07:53 AM | #14 |
Paint can smoker.. |
Thread Tools | |
Display Modes | |
