03-20-2015, 02:49 AM | #1 |
Ignition coil with resistor
I had an ignition coil fail on me recently and the only one I could find to replace it at short notice was supposed to have a resistor used with it. Fortunately, someone there knew how to connect it, Is it just connected in series with the coil? What is the point of it anyway? Is the coil actually made for a lower voltage and the resistor is left out of the circuit while the battery is cranking the motor and therefore only able to deliver a lower voltage but drops the voltage to the coil during normal running?
I've converted to 12 volts.
03-20-2015, 03:01 AM | #2 |
Re: Ignition coil with resistor
If you have converted to 12 volts you need to coil and resistor combination. Either in the coil or external to it.
For those that are 6 volts, you need a coil designed for an external resistor. There were ign systems that were designed to add and remove resistance during starting and running, but not the A. http://en.wikipedia.org/wiki/Ignition_coil
03-20-2015, 06:32 AM | #3 | |
I'm aware the A didn't have a resistor. The coil I have is clearly marked 12 Volts, yet it has a resistor. It is therefore clearly intended to run on less than 12 volts. It is not a 6 volt coil in a 12 volt system with a resistor to drop the voltage at the coil to 6 volts.
I'm part of the only ever generation with an analogue childhood and a digital adulthood. Last edited by Synchro909; 03-20-2015 at 06:38 AM. |
03-20-2015, 06:49 AM | #4 |
When 12-volt ignition systems first came out about 1955, car makers continued to use the 6 to 8-volt coils they had with the 6-volt ignition systems, so a resistor was used to reduce the voltage. A three position ignition switch was used so when starting the car, the resistor was bypassed and the coil got 12 volts. When the key went into the run position, the resistor went back into the circuit so the coil ran with 6 to 8 volts. Some coils had the resistor built-in, and others had an external resistor.
High energy ignitions (HEI) systems resulted in another change, and coils in this type of system are truly 12-volt coils.
Bob Bidonde |
03-20-2015, 07:06 AM | #5 |
With a coil that uses an external resistor you should see 1.2 to 1.4 ohms across the primary.
Coils with an internal resistor (for 12volt systems) should read about twice of that above, 3 ohms. Coil test
03-20-2015, 07:12 AM | #6 |
03-20-2015, 08:06 AM | #7 | |
Discussion of the difference in resistance of a 6v and 12v coil at http://www.yesterdaystractors.com/cg...rtips&th=26558 - and the use of resistors to achieve a correct current. Joe K
Shudda kept the horse. |
03-20-2015, 09:23 AM | #8 |
And...there are quite a few different values of resistance in the resistor, so when buying a coil match up the resistor at same time by the catalog rec or from OEM usage. And, of course, find out if it even uses one or has its resistance internally! Reistor application is not generic.
And there were also 6 V coils that used a resistor too, including early V8 Fords and some others. Don't buy a coil and a resistor separately without reference to what the coil requires. |
03-20-2015, 09:33 AM | #9 |
Did your other coil fail because it was oil filled and mounted upside down?
03-20-2015, 10:55 AM | #10 | |
As others have said, the use of a 6 volt coil running on 12 volts during the start of the engine helps to deliver a "hotter" spark during the startup of the engine. Marc |
03-20-2015, 11:11 AM | #11 |
Just to add to the conversation the starter was tied in front of the resistor and powered the coil during the cranking cycle. If you're cranking the engine and the battery breaks down to 9.5-10V you get better firing voltages to the plugs while cranking. Every volt counts toward upping KV firing voltage
Chev used this early on in a "foot feed" starter. The switch used a resistor bypass. You may notice starter solenoids are marked S and R
Mike Stitt "A business that make nothing but money is a poor business." -Henry Ford |
03-20-2015, 12:02 PM | #12 |
Tom I live in rural Nevada and when you break down it is a long way to get parts. I always install a coil with primary facing up. Learned that as a kid. Good Day to ya. Dan
03-20-2015, 02:09 PM | #13 |
I'm just trying to keep this simple. I'm smart enough to understand about current. Most folks like simple, especially me.
That said, points do not like anything over 6-8 volts. Run 12 volts thru a set of points without a resistor/reducer stuck somewhere in front of them and see how long they last. Been through it. |
03-20-2015, 02:23 PM | #14 |
Patrick L,
Just trying to help. The 12 volts isn't the problem with the points...rather the increased current via ohms law is what damages the points. If you know this, then I'm just trying to keep the story accurate for those that are reading this thread and may not understand why 12 volts is a problem ? After all, many cars were built that ran 12 volts and points. Marc |
03-20-2015, 02:33 PM | #15 | |
Which one[s] ran 12 volts through the points ? |
03-20-2015, 04:07 PM | #16 |
Patrick L.
My 66 Olds Cutlass used 12 volts and points.... Not sure though why the question as many cars had 12 volts and coil\points. Marc |
03-20-2015, 04:16 PM | #17 | |
That didn't answer my question. Pretty much all cars in the 50s/60s were 12 volt and used points. But, none ran 12 volts through the points for more than a couple seconds, most didn't allow 12 volts through them at all. |
03-20-2015, 04:41 PM | #18 |
Patrick L.
Very confused...thought that we were talking about breaker points ? Signing off. Marc |
03-20-2015, 04:48 PM | #19 |
03-20-2015, 05:32 PM | #20 |
Snyder’s installation instructions:
A-12000 COIL This coil is imprinted that it is 12-volts, use with external resistor. If you are running 6-volts, the coil is good for 6-volts as it is, ignore the 12-volt writing on the side. If you are running a 12-volt system, you will have to add an external ballast resistor to the coil. This coil is only 12-volt if it is used with an external ballast resistor. Afordman31 |
