03-25-2020, 10:25 PM | #1 |
56' 312 No Spark..finally figured it out! and some transmission help
This post is to share how I pulled my hair out for month troubleshooting a no spark situation. I scoured this forum and couldn't find a clear solution and learned alot as I read to lead me to thinking clearly.
I been cosmetically restoring my 312 to solve major leaks and replacing components that were not correct or missing. Did not feel a major overhaul was needed at this point. Before I started, the motor ran just fine after 30 years of storage. I replaced timing gears/chain and pulled the distributor to make timing the best it could be. Long story short, painted and put all back together and no spark. Turns out when I pulled the distributor and cleaned up, upon assembly and unbeknownst to me, the small paper thin insulator between the distributor body and bolt that secures lead to the points was grounding out due to the leading edge was missing. There was just enough missing to ground. I put some electrical tape to replace the worn insulator, buttoned it all up and my 312 came alive! I searched and could only find the insulator in a kit on a farm tractor website. Here are some pics of it and my solution as well as before and after pic on engine. Last edited by My Old Blue; 03-27-2020 at 08:34 PM. Reason: Updated the title for transmission help |
03-26-2020, 08:49 AM | #2 | |
Re: 56' 312 No Spark..finally figured it out!
03-26-2020, 11:13 AM | #3 |
Great detective work!
But watch out for corners of metal parts poking thru the electric tape fairly soon. The tape isn't very substantial and will soften from engine heat. If you want the real part you should order it. Or you could cut a small rectangle from a harder piece of plastic packaging material. example: water or milk bottle, one of those nearly impossible to open blister packs, etc. . Last edited by dmsfrr; 03-26-2020 at 12:32 PM. |
03-26-2020, 11:41 AM | #4 |
Yes! Temp fix for now. That kit is not a lot of $$ and will go that route before I get on the road. Thought I'd share that kit as I couldn't find it anywhere on traditional car part sites other than that tractor supply.
I have bigger issues now with with my shade tree attempt to seal up trans and now trans won't go into any gear..grr...that is for a other post after some research. |
03-26-2020, 12:06 PM | #5 |
A piece of Fish paper will do the job. It is a durable, flexible, electrical insulator that’s made of vulcanized fiber. It's available a electronic supply stores and even on ebay. if the wire is the problem, I believe there is fish wrap
03-26-2020, 12:48 PM | #6 | |
Example page... https://www.classictbird.com/Ignitio...roducts/45/2/0 . Last edited by dmsfrr; 03-26-2020 at 01:09 PM. Reason: add link |
03-26-2020, 12:50 PM | #7 |
Fish paper...that is a new term to me. I'll look it up. Thanks for the tip!
03-26-2020, 01:20 PM | #8 | |
On your trans, did you reseal the shift shaft and throttle valve shaft seals? If so, the internal linkage may be out of place and not moving the shift valve. There is a pressure test port on the lower left front side of the case. It is an 1/8" pipe plug. Hook up a gauge to read pressure. If I remember, it should be around 40-50 lbs. in forward gears and 200+ in reverse. If zero, maybe fluid is low. If it sat a long time, fluid drains out of the torque converter back into the pan so if you drained the fluid before the engine was started it will take extra fluid to refill. If you have pressure, watch the gauge as you shift the lever. The needle should twitch at each shift. If not, the internal linkage may be disconnected. |
03-26-2020, 01:35 PM | #9 | |
03-26-2020, 11:59 PM | #10 |
On the '55, 272 V8 distributor, the factory installed a round phenolic bushing thru the hole which isolated the threaded stud from the distributor body. As I recall, they did have a cheap piece of paper on the backside where the bolt goes thru.
However, you don't need to use any of that hardware if you get the modern distributor wire which has a built-in chamfered rubber plug that goes thru the hole in the side of the distributor. Many people have opted for this conversion and it is offered for all '54 thru '64 Y-block distributors. |
03-27-2020, 02:20 PM | #11 | |
If you go this route don't pull hard on the long end of the wire when installing, if the fit is a bit too snug it's possible to break the wire inside the insulation and get an intermittent or no connection. (don't ask how I know) |
03-27-2020, 02:23 PM | #12 | |
03-27-2020, 02:23 PM | #13 |
Great insight! Thank you.
03-27-2020, 05:24 PM | #14 |
The aftermarket 1-piece wire I spoke of is being used by the distributor rebuilders. Some of the Repro parts suppliers are offering it also.
dmsfrr is correct about being careful when installing the wire. This type of wire is a type known as "machine tool wire" which is characterized by having smaller strands of copper, but more of them, so that there is maximum flexibility. The smaller strands would be much easier to break if you pulled on the wire too hard. The best way to install them is to have the breaker plate removed so that you can push the enlarged "plug" portion of the wire into the hole from behind. But it can be done without removing breaker plate with a little enginuity and some small screwdrivers and small copper baling wire. |
03-27-2020, 06:20 PM | #15 |
You may have a leak inside the transmission. They loved to use tubes that are basically just a push fit. Those piston ring seals are also part of the fluid flow between the shaft and the distributor sleeve there. The rear band has to work in low and reverse and the front band has to work in intermediate gear along with applicable clutches and that stuff takes a good adjustment and pressure to work properly. This is why I think it sounds like a fluid pressure problem. If the throttle valve arm and gear selector arm are in position then that's the tack I would take in troubleshooting it.
03-27-2020, 08:23 PM | #16 | |
Thanks for letting us know about this kit. I actually ordered one as I have a distributor I am working on and the piece in there broke on me.
03-27-2020, 08:30 PM | #17 | |
Sounds like I do have a pressure issue and will get a gauge on and top off with another quart before I pull the pan off. Note that this trans has worked flawlessly before storage and even after coming out of 20+ year storage. |
03-27-2020, 08:40 PM | #18 |
05-23-2020, 09:38 PM | #19 | |
