09-18-2017, 06:07 AM | #1 |
Possible Vapor Lock ???
Lately I have an issue with my 31 coupe stalling out and hard starting after she is hot and sits for a while. She starts right up cold, we go for a ride on a hot day, I park the car and do not shut the fuel off, she might sit for 20-30 minutes. I go to start it and she starts but dies in a few seconds then I have to crank and crank and usually she will not start unless I leave it sitting for an hour our more. I noticed when I bought the car the previous owner did not lock down the fuel cap tight but I do. Also wonder if I should always shut the fuel off even if its only for a short time once hot.
09-18-2017, 08:11 AM | #2 |
Re: Possible Vapor Lock ???
Turn the gas off a couple hundred yards before you stop and turn the engine off.
The lower gas in the carb might help with the problem of today's gas boiling so easily. |
09-18-2017, 08:30 AM | #3 |
Pour some water on the bowl of the carb. It will start right up. Common problem.
09-18-2017, 11:57 AM | #4 |
Try leaving the gas cap loose like the previous owner, its very common problem! If that then fixes your problem, we can then fix the gas cap :-)
09-18-2017, 01:01 PM | #5 |
31 Tudor 66 Bonneville 57 Chevy pickup 27 T roadster pick up |
