05-13-2010, 10:51 AM | #1 |
What weight oil in the engine
What weight oil do most guys run in there Model A engines
05-13-2010, 10:53 AM | #2 |
Re: What weight oil in the engine
there was a survey done on this maybe someone has it saved and can post it.
05-13-2010, 10:56 AM | #3 |
Banned
Check the survey. Somebody had posted a link to it...I simply use 10w-40w, any brand. It only stays in the engine for 5000 miles or one season. Then it goes into my Ford Expedition for a while before I take it recycling. TOM IS CORRECT. I MEAN 500 MILES.
Cam-2~20-50 was good racing oil. Always had better oil pressure with Cam-2 from Sears then with Casteroil GTX 20-50. But then again since Model 'A's have nearly no oil pressure to begin so with why try to push 'mud' through the pump and free fall back down? It's flow baby! Some 26 pts a minute at 1300 rpm. [I can't remember if that crank shaft rpm or oil pump/distributer rpm] That's really what cools the engine more then water in my honest ops. skip. Last edited by skip; 05-21-2010 at 10:32 AM. |
05-13-2010, 10:57 AM | #4 |
I like Shell Rotella T 15W-40 because of the zinc content. I know it is pricy, but so is a rebuilt engine.
05-13-2010, 10:57 AM | #5 |
Survey says...
Click on link below for oil survey results.
Oil Survey You might also look at the Add Ons survey. It has information about aditives. Add On Survey Bob Last edited by Bob Johnson; 05-13-2010 at 11:01 AM. Reason: Additional survey information |
05-13-2010, 10:59 AM | #6 |
05-13-2010, 11:03 AM | #7 |
I've been using diesel engine oil. It's super heavy duty and has many of the additives that have been removed from normal gas engine oil. This year, I am trying Mobil 1 5W40 A little thinner when cold to help with flow, then 40W when hot. So far so good. I do run a filter, don't drive the car more than 1000 / year so I only change it in the spring.
05-13-2010, 11:38 AM | #8 | |
I use Shell Rotella 15-40 the same as Doug. |
05-13-2010, 11:40 AM | #9 |
05-13-2010, 11:42 AM | #10 | |
05-13-2010, 11:52 AM | #11 |
I tend to use my coupe all year and have 15-40 oil in it with very good results. I had 20-50 in it but I feel that's a little too thick in cold weather. With 15-40 it turns over easily, doesn't leak or burn and I change it when it starts to look dirty on the stick. I don't run a filter.
05-13-2010, 12:05 PM | #12 |
Banned
Sorry. I mis spoke. Make that about 500 miles. Thanx Tom.
05-13-2010, 12:10 PM | #13 |
15w40 rotella has more zinc content than the others
05-13-2010, 12:59 PM | #14 | |
05-13-2010, 01:31 PM | #15 | |
i hear ya, amen |
05-13-2010, 02:03 PM | #16 | |
guess what there is no powertrain warranty without oil change receipts and documentation |
05-13-2010, 03:01 PM | #17 |
Non detergent 30 weight (pre 1963 oil). Added a bottle of Zinc additive at the last change. Change every 6 months.
05-13-2010, 03:38 PM | #18 |
I, personally like Shell Rotella 15W-40, having a viscosity close to what Henry recommended of 15 when clod and 40 when warm. The original recommendation was for 20 weight in winter and 30 weight in summer.
The Shell Rotella is also heavy on the ZDDP additive which has been around since the mid 1930s and I feel has helped our engines last eighty years. There is no one answer for BEST, just a lot of valuable opinions. |
05-13-2010, 04:00 PM | #19 |
10,000 miles a season, Shell Rotella 15W-40, changed every 500 miles.
I've been hearing that the zinc is being removed or eliminated in even the "diesel" oils. But I cannot find anything definitive on this. Anyone?
I know a lot of things; I just can't remember them all. 1928 CCPU 82-A 1931 Roadster 40-B Dlx (Canadian) |
05-13-2010, 04:30 PM | #20 |
zinc has been reduced in diesel oils and this fall is being reduced even more. i forgot where i read it but rotella 15/40 has the highest zinc levels compared to most of the other oils
05-13-2010, 08:44 PM | #21 |
Straight 30 weight, no filter, change every 500 miles. My oil of choice is Farm & Fleet at about $1.25 per quart. Oh, and detergent.
05-13-2010, 08:57 PM | #22 |
I use mobile one 10w30 and Marvel Mystery Oil with it and i LOVE it. Runs like a top and smooth
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
05-13-2010, 09:03 PM | #23 | |
The Shell Rotella is also heavy on the ZDDP additive???
How does the zinc help the engine that is in the Rotella?? or the ZDDP please mark
05-13-2010, 09:25 PM | #24 |
HD 30 detergent and changed at 500 miles; fresh oil change in fall prior to winterizing
Dave A Jamieson Portland, ON Canada 1928 Tudor |
05-13-2010, 11:06 PM | #25 |
About 4 pounds.
05-14-2010, 12:28 AM | #26 |
05-14-2010, 01:59 AM | #27 |
I'm weighing in with 30w. That is what we used in the garage I worked in. Brand didn't seem to matter. One thing to note is that I saw someone post 5w-30w. Something to be careful of here is the oil being so thin that it seeps thru the gaskets. I ran some 5w-30w in a 67 camaro of mine and it started to seep out. I went back to 30 and it seems to have stopped for the most part. I've heard it said that once oil makes it past a gasket, it continues to seep....anyway...my 2cents.
05-14-2010, 09:42 AM | #28 |
For what it's worth, I run Rotella in my 1998 E-350 7.3 diesel van. Oil change 3000-5000 miles. It has 403,000 miles and has never required any engine work save three fuel injectors.
05-14-2010, 10:39 AM | #29 |
Re: The Shell Rotella is also heavy on the ZDDP additive???
The Zinc, in the form of ZDDP, is a lube for valves and such. It is an additive that was removed from oils with the SM rating and the "Sunburst" stating "Safe for ALL Gasoline Engines." It was removed, (or not added) to assist the latest catalytic converters. I spoke to Shell's Technical Customer Service chemist who advised me that Rotella still has enough zinc added to meet our needs.
05-14-2010, 12:54 PM | #30 |
BFD, Congratulations! you get the first oil question trophy of the new Ford Barn. :>)
08-19-2012, 07:40 PM | #31 |
Studied the oil survey and the great number of thoughts and advice posted on this subject. Ultimately decided to go with Shell Rotella T (I think the "T" is the latest version of Shella Rotella) 15w-40. I am not sure when the oil in this Model A was changed last, or what type of oil is in it now. Will be checking the oil pan for sludge. Changing the oil every 500 miles will be a bit pricey with this oil but, as many of noted, it is better than having to rebuild an engine. The prior posts on this subject were very helpful, thanks guys.
08-19-2012, 09:46 PM | #32 |
So what happens if you mix detergent and non-detergent?
08-19-2012, 09:54 PM | #33 |
Model A owners manual says 20 in winter and 40 in summer .
08-19-2012, 10:10 PM | #34 |
In my B engine delivery I run 20-50 synthetic Valvoline with an oil filter. In my other cars,(nonfiltered), i run 30w and change it every 500-600 miles. I'm about to put an aFordable filter on the almost new engine in my latest restoration. I think I'll go with the 20-50 synthetic and change it at 2000-3000 mile, or one year, intervals.
08-19-2012, 10:40 PM | #35 | |
I go Mobil One Synthetic 5W30 every 700 miles or so in my Model A rebuilt HC engine that doesn't burn oil, and just "marks it Territory" a bit, and Mobil One 5W30 every 5,000 miles in my 2012 Mustang as per Mustang owners manual. I now am using my left over gallons of ROTELLA 15W40 in my boat's diesel, and am pleased how clean it always looks. The boat, also doesn't burn any oil between annual changes. |
08-23-2012, 10:47 PM | #36 | |
What I don't like to do is clean that damn screen. PITA. How often do you guys remove the screen and clean it?
Forty horses is plenty. |
08-24-2012, 04:30 AM | #37 |
If you use detergent oil you shouldn't have to clean the screen around the oil pump intake until it's time to take up babbit clearance, or rebuild the engine.
08-24-2012, 10:57 AM | #38 |
I use Walmart 20W50 in all of mine. I used Havolene 30 weight high detergent in my 31 tudor for years until it got hard to find in my area.
08-24-2012, 12:24 PM | #39 |
As one can see by the thread just about any oil that is designed for vehicles can be used successfully in the Model A, or AA.
08-31-2012, 01:14 PM | #40 |
20 w 50 plus a half a quart of Slick 50.
Wayne |
08-31-2012, 08:08 PM | #41 |
Not that I have used it in a Model A but I really, really like Brad Penn oil!
1927 Model T 1930 Standard Roadster 1930 5 window coupe 1931 Tudor Sedan "If it was easy, everyone would do it" |
