Old 12-16-2014, 01:38 AM   #21
Brother Hesekiel
Brother Hesekiel's Avatar
Default Re: Firewall Patent Data plate question
Let's recap: when the car got its engine at the factory, the engine was stamped with the frame number. The body was then put on the frame, and that number was never visible again, unless you were to lift the entire body off the frame again.
The engine/frame number eventually became the VIN. When now another engine was installed, no number that had any reference to the car or the paperwork was visible anymore. Unless you were to lift the body off the frame, you'd never know if that was the car that corresponds to the VIN on the title. Therefore, people either stamp a visible part of the frame (i.e., under the floorboards) with the VIN, or, less invasive, just mount a plate with the VIN on the firewall, so that the good DMV inspector doesn't have to order the car owner to remove the body from the frame. Does that make sense?
Here's the data plate I fabricated for my Model T Speedster:
I should mention that registering a car to the engine number was common practice in the US in the 1950s and even early '60s. We had plenty of cars where the original engine was gone and no number existed anymore. A plate is an easy fix for that.
Brother Hesekiel is offline   Reply With Quote
Old 12-16-2014, 01:50 AM   #22
CarlG
CarlG's Avatar
Originally Posted by Brother Hesekiel View Post
Let's recap: when the car got its engine at the factory, the engine was stamped with the frame number. The body was then put on the frame, and that number was never visible again, unless you were to lift the entire body off the frame again...
Actually, it was the other way around. The engine was stamped with a number when the engine was assembled. Then the frame was then stamped with the engine number when the engine was installed in the frame.
The rest is OK.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 12-16-2014, 02:06 AM   #23
Tom Wesenberg
Tom Wesenberg's Avatar
Originally Posted by d.j. moordigian View Post
If that is an original number to the block,....it will be a 5 main cam block.
Also, the pads at the back of the block, were the flywheel housing / throttle
assemble bolts,...will have round pads.
This engine is about 60,000 engines after my 28 engine was built, and on my engine Ford already quit using the #2 and #4 cam bearings, so the factory rough turned the bearing surfaces undersize, just to make the cam easier to install. Sure seems like a dumb move to me. Why not just use up the parts as originally designed, then as parts are used up put together engines minus the 5 bearing cam and blocks with 5 bearings for the cams?
Old 12-16-2014, 04:01 AM   #24
Charlville
Charlville's Avatar
When you import a car into the UK and have it MOT tested they are often quite fussy about having a VIN plate, so I just bought one of the accessory ones and rivetted it to the bulkhead just for peace and quiet sake
Kevin Flood
West Berkshire UK
Member MAFCGB, VHRA, SAH, Brooklands Trust
Sporadic progress on My 1929 Sport Coupe can be found here along with my blog
http://automotiveamerican.com/
Charlville is offline   Reply With Quote
Old 12-16-2014, 11:43 AM   #25
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
On Mineva, I looked up one of the patent numbers, It was for an overhead valve set up, using rocker arms! Another was for the pivoting bell, at the front of the torque tube. All patent number plates "MAY" not be the same, depending on the production date of the car??? Minerva was an Early '30 Standard 45-B Coupe.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 12-16-2014, 02:33 PM   #26
Tom Wesenberg
That overhead patent would be interesting to see. I wonder if Ford ever made one to try it out in the shop?
Old 12-16-2014, 04:31 PM   #27
CarlG
CarlG's Avatar
These are listed on eBay for $25 -- They will stamp any number you want on them.
http://www.ebay.com/itm/Stamped-Ford...2cfda9&vxp=mtr
Alaskan A's
Old 12-16-2014, 04:53 PM   #28
pooch
pooch's Avatar
When I registered my last model A, they wanted a chassis number, I just plucked one out of a list .
I figured about 4 to 5 million A/s built, over here in NSW .... maybe 1000 still alive and registered in the state... that is about .0045 % chance that the number I picked would be known on the state records.
More chance of winning the lottery.
One old hot rod guy said he buys old blocks that will never see a car again and gets the number off them, and uses that for rego.
For .0045% chance, I could not be bothered .
pooch is offline   Reply With Quote
