09-20-2017, 08:37 AM | #1 |
Column drop switch what does it control?
On my '41 coupe my column drop switch has some extra wires on it and also some wires that are cut off, I know one of the wires goes to an electric fuel pump with a momentary contact switch in between. I know the ignition circuit is controlled by the drop switch. My concern it that the unknown extras may draw too much current. Car is 6 volt pos ground. Anyone have a wiring diagram or is one listed in a book I should have.
09-20-2017, 08:54 AM | #2 |
Re: Column drop switch what does it control?
There should only be three wires connected to the ignition switch: Power, Coil & Gauge. Adding extra wires can easily overload the switch. I would connect add-ons to the stud on the CB panel where the power wires from the battery and generator connect. A nice clean installation would be a wire from this CB panel stud to a switch panel and make any additional connections at the switch panel.
09-20-2017, 09:05 AM | #3 |
Vanpelts for schematic--
http://www.vanpeltsales.com/FH_web/F...ing1941car.jpg
09-20-2017, 10:56 AM | #4 |
Thanks guys, looking at the rest of the under dash wiring I think I should get a new harness.
09-20-2017, 12:27 PM | #5 |
09-20-2017, 01:09 PM | #6 |
09-20-2017, 10:43 PM | #7 | |
09-21-2017, 10:39 AM | #8 |
I notice you live in a cooler part of the world. Try moving to a warmer part and see how long it lasts with continuous use of all that stuff. A 30 to 35-amp system can only handle so much. I do have to agree that the original equipment switches were a much better quality Bakelite type with good quality metal contacts but many folks may have the modern replacements that are not as reliable. This is why I stand by my recommendation. What works for you may do damage for someone else.
09-21-2017, 08:11 PM | #9 |
That is a wonderful response to those who don't understand watts/volts/amps, etc.
The old stuff was built to lower (read higher) standards than today. Now, if the circuit has to handle 15 amps, design it for 16.5 (10% increase). Back then, it was kinda sorta does it look good. |
