03-14-2018, 05:09 PM | #1 |
8ba fuel pump
I have a 8ba in a model A. The firewall is recessed for clearance, the stock glass bowl fuel pump won't clear the firewall. Did Ford make a 8ba pump with no glass bowl?
03-14-2018, 05:57 PM | #2 |
Re: 8ba fuel pump
Have you tried "clocking" the bowl? You remove the 6 screws holding it together and then assembling the two parts in a position that will fit. There are earlier [pumps with no bowl that can probably be made to fit. It might take some mixin' and matchin' parts and a different pushrod, though. I have never had to do this so I don't know for sure.
03-14-2018, 07:42 PM | #3 |
Re: 8ba fuel pump
Do as Tubman suggests.
03-14-2018, 08:35 PM | #4 |
Re: 8ba fuel pump
Never thought of that, thanks!
03-14-2018, 08:41 PM | #5 |
Re: 8ba fuel pump
I think 34 didn't have a bowl. What ever is on my 46 does not have a bowl.
03-14-2018, 08:45 PM | #6 |
Re: 8ba fuel pump
03-15-2018, 12:44 AM | #7 |
Re: 8ba fuel pump
Since the diaphragm bolt pattern are the same you can use the lower part that fits the 8BA pumptower and the upper part from a pump without the glassbowl to.
There are non ford AC pumps with the glassbowl centered on top also as an option. |
03-15-2018, 09:38 AM | #8 |
Re: 8ba fuel pump
Yes, I remember my dad had one of those vertical bowl fuel pumps on the 52 Merc for a while. I've still got it but somebody damaged the threads on the fuel inlet.
https://www.youtube.com/user/roosty6/videos Last edited by RalphG; 03-15-2018 at 01:15 PM. |
