07-07-2016, 03:22 AM | #1 |
Ardun question
Ardun overhead valve query. This little piece was missing out of the kit. My father passed recently and I have inherited his project. He had never opened the crate since the early 1990s and so now I have my engine guy working on it and this one doohicky is missing. Does anyone know if this is a standard item off the shelf from some other engine or is it a one off. I have emailed H&H Mike for help. The time zones are killing me and Don Ferguson is not email friendly. Any help would be invaluable. Brom |
07-07-2016, 08:45 AM | #2 |
Re: Ardun question
That's an adjustment ball stud for the pushrod end of the rocker arm. There are some other 50s-era engines that used similar adjustable rocker arm designs that may have an adjuster that could be used - something such as early Hemi, Olds Rocket, Nailhead, etc.
Mike Wanted: - '32-34 Open Cab Pickup (RPU) parts and documents/articles/info - ARDUN parts |
07-07-2016, 08:50 AM | #3 |
Re: Ardun question
Thanks Mike. The search continues. Ill check out the parts from the manufacturers you mentioned.
Brom |
07-07-2016, 09:15 AM | #4 |
Re: Ardun question
Brom, post dimensions of the adjuster with the length, ball and thread diameter and TPI count and there is a fair chance someone will know the original application.
My school colors are black and blue, I attended the School of Hard Knocks where I received a Masters Degree in Chronic Mopery. |
07-07-2016, 11:58 AM | #5 |
Re: Ardun question
Google "reproduction ardun heads" and see if any of the people reproducing the heads use that part and might be willing to sell some.
Charlie Stephens |
07-07-2016, 12:05 PM | #6 |
Re: Ardun question
07-07-2016, 01:26 PM | #7 |
Re: Ardun question
Why not give Don a call?
Ardun Enterprises Don Ferguson P.O. Box 205 Wilmington, CA 90744 (323) 775 - 6803 Phone (310) 834 - 9904 FAX
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC |
07-07-2016, 04:19 PM | #8 |
Re: Ardun question
On an old Ardun build weused different push rods and had to change the rocker adjusters. I don't know which one we used but the thread was a standard size. This does not look like the stock unit and it might depend on the push rods. The stock ones were solid and prone to bending. I'm sure Don could give you the help you need. There were also long and short lifters.
Thread Tools | |
Display Modes | |
