Old 02-03-2020, 07:12 PM   #1
keyswitch1
Default steering box
I saw some where that people added a grease fitting on the bottom of the steering box to lube it.
My dumb question is can I put the grease in where the plug is on top of the box ?? My old age and bad back does not feel like making the grease fitting on the bottom of the box
keyswitch1 is offline   Reply With Quote
Old 02-03-2020, 07:45 PM   #2
arnhemmer
Default Re: steering box
Don't use grease to lube the steering box. Since it is not a liquid it won't flow between the gears thus drying them out. It will just be displaced by the gears. Use the proper gear oil to lube the gears.
arnhemmer is offline   Reply With Quote
Old 02-03-2020, 08:34 PM   #3
Jacksonlll
Jacksonlll's Avatar
That fitting is to lube the sector shaft bushings.
Old 02-04-2020, 12:25 PM   #4
katy
katy's Avatar
How does a grease fitting on the bottom lube the sector shaft bushings?
Old 02-04-2020, 04:39 PM   #5
Jacksonlll
Jacksonlll's Avatar
It’s installed between the two bushings and the lube goes between them. Some cars have this. I’m talking two tooth
Old 02-04-2020, 05:21 PM   #6
old31
Doesn't the fitting on the top of the box provide lube for the entire box? Why would you need a fitting on the bottom of the box?
old31 is offline   Reply With Quote
Old 02-04-2020, 06:08 PM   #7
Werner
Werner's Avatar
This applies to the 7-tooth steering: green is oil 600/680. Red is high pressure grease.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 02-04-2020, 10:29 PM   #8
whirnot
whirnot's Avatar
No, the sector bushing are greased from the bottom. The oil from the box should not go past the first bushing. Keeping the sector shaft greased also aids in keeping oil from seeping past these bushings.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 02-06-2020, 12:25 PM   #9
Bob Bidonde
Bob Bidonde's Avatar
I put grease in the Gemmer gear box to seal the sector bushings, then I put a few table spoonfuls of SAE 140 gear oil in the box. This technique stops the inherent oil leakage, and I have been doing it since 1962. It works!
Bob Bidonde
