Old 03-13-2019, 12:09 AM   #1
Ian NZ
Ian NZ's Avatar
Default Ford Model A Klaxon horn
Would anybody know anything about or the make of this Model A klaxon horn.
Ian NZ is offline   Reply With Quote
Old 03-13-2019, 12:57 AM   #2
Tudortomnz
Tudortomnz's Avatar
Default Re: Ford Model A Klaxon horn
G'day Ian
That horn appears to be a modern era repro horn, not Model A horn. It may be 12v.
The horn on your '32 will be the same as the A, except for the motor cover.
Cheers Tom in NZ.
Tudortomnz is offline   Reply With Quote
Old 03-13-2019, 01:16 AM   #3
Bick in New Zealand
Bick in New Zealand's Avatar
Hi Tom & Ian,
They were very common here in the 70's and cost approximately $20. They were made by Hutchins. I have an original '32 sparton motor cover, if you need one Ian.
1928 Roadster (CA67)
1931 Deluxe Coupe RHD
1931 Victoria RHD
Model A's don't leak oil they just mark their territory.
Bick in New Zealand is offline   Reply With Quote
Old 03-13-2019, 02:07 AM   #4
Ian NZ
Ian NZ's Avatar
Hi Tom & Bick Thanks for the information. I have just now bought a original Model A Sparton horn on Trade me as the one on the 32 sounds a bit sick. the trouble is a lot of these horns have originally been run on 12 volts which does not help them.so I want to and replace it with another one with improvements. That Hutchins horn has just came up for sale on Trademe.
Old 03-13-2019, 04:56 AM   #5
woofa.express
woofa.express's Avatar
love your signature Bick. I quote it from time to time. today I scored some discarded carpet I need to place under Woofa Express. the person discarding it asked what I'd want it for and I quoted your signature. cheers, gary
I know many things,
But I don't know everything,
Sometimes I forget things.
And there are times when I have a long memory.
woofa.express is offline   Reply With Quote
Old 03-13-2019, 07:17 AM   #6
Joe K
Joe K's Avatar
In depth discussion of Hutchins horns. Including the fact that in 2016 they were still available new and the owner of the company posted here.
https://www.fordbarn.com/forum/showthread.php?p=1286438
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 03-13-2019, 01:36 PM   #7
Bick in New Zealand
Smile Re: Ford Model A Klaxon horn
Thanks Woofa.
1931 Victoria RHD
Old 03-13-2019, 01:40 PM   #8
Bick in New Zealand
Ian, I just had a thought that the base plate on the '32 Sparton is different to the Model A, to accommodate the '32 cover. Someone with more knowledge of this will hopefully chime in with the facts.
1931 Victoria RHD
Old 03-13-2019, 04:24 PM   #9
Ian NZ
Ian NZ's Avatar
The 1932 cover fits straight on but base plate which takes the 32 mounting bracket is different so the six holes with the bolts that clamp everything together have to be rearranged thats what I had to do to the Model A Sparton horn I have on the 32.
