Old 10-29-2018, 12:58 PM   #1
kimeccles
kimeccles's Avatar
Default 1930 Cabriolet pass door lock question
Hi,
I just put my original passenger door lock back in and when I turn the key so the door opens, it seems fine and the key comes out and lock stays where it belongs.
But when I try to lock the door, it does lock, but when I pull the key out the entire inner key cylinder comes out. I can put it back in and all seems fine, but what am I missing to keep the lock internals inside the car?
I see what I think were tiny oil holes, and I do have the keeper screw in that holds the lock assembly in place on the side of the door. The problem is the insides of the lock come out.
thanks,
Kim
68B frame# late May1930, fixed seat, Briggs build plate# & most parts, indicate July, or early Aug. 1930.
kimeccles is offline   Reply With Quote
Old 10-29-2018, 02:15 PM   #2
jw hash
jw hash's Avatar
Default Re: 1930 Cabriolet pass door lock question
either you have the wrong lock cylinder or someone removed the cover on the original that holds the lock together. on the original there is a cover that is crimped around the outside edge of the lock cylinder together.
jw hash is offline   Reply With Quote
Old 10-29-2018, 04:20 PM   #3
kimeccles
kimeccles's Avatar
Thanks. I took it out and looked more closely and it has cracked so the retainer ring broke off as mentioned above.
Now to make matters worse, the keeper screw in the door to hold the lock housing broke off inside.
Pandora strikes again. Best to leave her alone for a while.
Old 10-29-2018, 05:48 PM   #4
figment
The original keeper screw is only about 1/4 inch long and is slotted . When seated against the lock it does go quite deep into the door wood . I have not seen one broken because it is so short . But you might be right . Norm
figment is offline   Reply With Quote
Old 10-29-2018, 06:36 PM   #5
jw hash
jw hash's Avatar
kim
on the keeper screw. there is a little insert that the lock screw, screw into, with the lock cylinder out of the door take a screw driver put it in the slot of the screw and push it into the hole it will come right out. let me know if you need another insert. I do have some extra's
