Old 07-05-2019, 10:15 AM   #1
37 truck
Default Priming engine with oil
I had my flathead rebuilt about five years ago, and finally am getting close to starting it. I want to prime the engine with oil before starting. Everything was well coated with assembly lube, The engine is in the truck, and the pan is on so I can't pre prime the oil pump. Ideas like adding oil through the pressure gauge location have been discussed. Ideas?
37 truck is offline   Reply With Quote
Old 07-05-2019, 10:41 AM   #2
Jack E/NJ
Jack E/NJ's Avatar
Default Re: Priming engine with oil
Yep, that's what I've ever done. Just stick a funnel in there and let a quart or two slowly percolate down in there. Others have use a small drill pump. Jack E/NJ
Old 07-05-2019, 10:50 AM   #3
RalphM
RalphM's Avatar
Napa sells an inexpensive oil pump that is used with a drill motor.
RalphM is offline   Reply With Quote
Old 07-05-2019, 11:41 AM   #4
Kube
Kube's Avatar
I use a unit that is very similar to a brake bleeding unit. I attach where the oil sending unit is mounted. This will push oil though all of the bearings, etc.
I started doing this to every engine I've rebuilt since the 1970's. Some with hydraulic lifters... this will push oil through them, the push rods, etc. Not a concern with a flatty but just an example of how well it works.
I am confident you could buy one of these quite reasonably these days at Harbor Freight, etc.
"Imagination is a crutch used by those who lack knowledge and intelligence ."
B
. Franklin
Old 07-05-2019, 01:45 PM   #5
alanwoodieman
I took a short length of plastic pipe 2" x 10" put cap on one end drilled for a fitting that matched the oil pressure fitting in the block, put a screw in plug on the other end with a air hose hole--attach hose to block, fill pipe with oil, screw in plug, blow low pressure air thru the hole 30lbs and that pushes the oil into the engine
Old 07-05-2019, 01:57 PM   #6
51504bat
51504bat's Avatar
Posted this over on the HAMB in response to a similar question:
Years ago the machinist at the local parts store used an old pressure bleeder tank for a pre-oiler. Dumped 5 qts. of oil in the bleeder tank which was connected to the engine with an oil fitting on the block and a shut off valve, pressurized the tank to 40 psi, opened the valve and instant oil pressure at start up. I made one for my 8ba start up from an old paint pot. For some reason didn't work as well as the brake bleeder set up but it got the job done. I've also heard of using a hand pump garden sprayer to achieve the same results.
Here is the link to the thread on the HAMB: https://www.jalopyjournal.com/forum/...#post-13148028
Old 07-05-2019, 04:41 PM   #7
Kerk
The only thing I can add is to tunn the engine Slowly while pressuring the system . Always did it on fresh rebuilds . Helps to have someone to do the turning. Run 3 or 4 quarts this way. Kerk
Kerk is offline   Reply With Quote
Old 07-05-2019, 08:25 PM   #8
Step-down
Step-down's Avatar
I bougth one of those plastic pump bug sprayer for garden store , added oil to the pump and threaded to the block where the oil sending unit would go. I pumped one Qt of oil into the block just before I fire her up. Primed the whole system and had oil pressure right away.
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
Old 07-06-2019, 01:25 PM   #9
supereal
supereal's Avatar
Adding oil allows it to flow down and through the valve chamber. Cranking a short time before turning on the ignition usually provides enough priming. The positive displacement oil pump does a good job. That is one reason old Fords have lasted so long.
supereal is offline   Reply With Quote
Old 07-08-2019, 05:48 AM   #10
Frank Miller
Frank Miller's Avatar
If you're running a stock filter then put a hose over the center tube with the filter out and fill the canister with oil. The oil will slowly drain back through the pump and it will be primed ready to go. The rest I just poured in the fill hole.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 07-08-2019, 10:36 AM   #11
37 truck
Thanks for your reply's, sense we are on the subject of oil, what is everyone using as a break-in oil these days?
Old 07-08-2019, 12:34 PM   #12
JSeery
JSeery's Avatar
Now you've done it!
Old 07-08-2019, 04:18 PM   #13
A bones
A bones's Avatar
How about anything you want to drain out in A hundred or so miles?
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
