Old 06-10-2019, 10:51 AM   #1
50droptop
Default 1936 floorboard screws
Does anyone know of a source for these screws and washers? They are for securing the wooden floorboard. They have the ends machined down to help alignment/starting. Also, they’re different from the wood floor support screws. I’ve checked McMaster with no luck. I’m one floorboard set short.
File Type: jpg 55EA7CF8-A3D9-4B5E-ADAE-0A29C461BBDC.jpg (29.5 KB, 78 views)
File Type: jpg 3A5E6C24-2CDA-46A2-A3CF-AA162E1076D2.jpg (37.5 KB, 81 views)
50droptop is offline   Reply With Quote
Old 06-10-2019, 11:03 AM   #2
Bob C
Default Re: 1936 floorboard screws
Maybe here. https://cgfordparts.com/ufolder/ford...hp?number=3141
https://www.bobdrake.com/FordItem.aspx?Item=3141
Old 06-10-2019, 12:34 PM   #3
rustythumb
bob is out of stock- what a shock!
rustythumb is offline   Reply With Quote
Old 06-10-2019, 01:18 PM   #4
Kerk
Call Joe's Antique auto parts. Has them in stock! tel.#508 278-3980
Ux bridge Ma will ship same day! Kerk. Sorry do not have catalogwith the 800 Handy .. Kerk
Kerk is offline   Reply With Quote
Old 06-10-2019, 08:57 PM   #5
50droptop
Iíll give them a call in the morning.
Thanks again all for the info!!!
Old 06-11-2019, 12:29 PM   #6
Ray in La Mesa
They look the same as Model A screws, might try Model A suppliers.
Ray in La Mesa is offline   Reply With Quote
Old 06-11-2019, 05:00 PM   #7
DavidG
DavidG's Avatar
Through '32 models they were 12-24 screws, starting with the '33s they were increased to 1/4-20.
Old 06-12-2019, 08:54 AM   #8
TJ
TJ's Avatar
The 1/4X20s can be found at a local Ace Hardware store. They won't be the black finish, but they do the job and are hidden under the floor mat. Some Ace stores also carry the recessed washers.
Old 06-12-2019, 08:58 AM   #9
deuce lover
deuce lover's Avatar
TJ is correct.Ace has them- zinc plated.
Old 06-15-2019, 08:17 AM   #10
Brendan
Brendan's Avatar
my 36 pickup is 12-24
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 06-16-2019, 08:42 AM   #11
50droptop
These are 1/4-20. I’m back home on Monday and will check out the local Ace Hardware. Also putting together an order for Joe’s Antique Auto....they’re on my list in case the Ace route falls through.
Old 09-07-2019, 01:31 PM   #12
FrankWest
FrankWest's Avatar
are the correct screws flat heads or dome heads?
FrankWest is offline   Reply With Quote
Old 09-07-2019, 01:48 PM   #13
FrankWest
FrankWest's Avatar
just a a dab of black flat paint.
Old 09-07-2019, 01:49 PM   #14
50droptop
Mine were domed head.
Old 09-07-2019, 02:22 PM   #15
FrankWest
FrankWest's Avatar
I should say oval head.
I was able to purchase slotted oval head counter sunk 1/4 20 stainless steel. on ebay.
Nice screws, but won't take gun bluing and have to paint. But that is ok, at least they look authentic. My car has mostly oval head, black, but need a few extra, car vendors only sell flat head? I think the originals are oval head? but maybe the manufacturer used flat head too? Don't know. Tried looking up in the green book, but still are looking. To bad they don;t have an index labeled Floor. Maybe I am getting too old?
Old 09-07-2019, 05:10 PM   #16
Don Rogers
Don Rogers's Avatar
The screws were flat head machine screws. When properly installed with counter sink washers they are flush with the floor.
Don Rogers is offline   Reply With Quote
Old 09-07-2019, 06:48 PM   #17
DavidG
DavidG's Avatar
I second Don's comments. Oval head screws make no sense as they would only create high spots on the floor mat which would lead to premature wear through.
Old 09-08-2019, 03:35 AM   #18
RKS.PA
RKS.PA's Avatar
Counter sink washers are essential to keep the wood from splitting under pressure. Made my own replacement set of boards.....easy and much cheaper than from Mac's. Used the old ones as patterns for my '39.
RKS.PA is offline   Reply With Quote
Old 09-08-2019, 07:28 AM   #19
50droptop
Just to clarify how my ‘36 was when I disassembled it. The screws that held the wooden floorboard supports were indeed flat head screws with counter sink washers. However, the screws that held the wooden floorboards (driver and passenger side) on either side of the transmission cover were oval head with countersunk washers. I don’t disagree that the oval head would sit up slightly higher under the front mat, and could possibly lead to premature wear, but this is how that car was assembled. Due to the similarities of these bolts to other Ford bolts (bottom threads smoothed to aid alignment-can be seen in the photo posted) and their consistent use on both floorboard sides; I have every reason to believe these are the original bolts Ford used in this application.
Old 09-08-2019, 10:14 AM   #20
VeryTangled
VeryTangled's Avatar
Originally Posted by 50droptop View Post
Just to clarify how my ‘36 was when I disassembled it... but this is how that car was assembled... I have every reason to believe these are the original bolts Ford used in this application.
Hi Everyone, This is gonna sound snarky, sorry.
50droptop, a person can believe what they choose.
For example I believe that with very few exceptions over eight decades every vehicle has been tampered with to deviate from the condition when it was originally assembled. Even on the absolutely most original car you can imagine, would you expect it to still have the oil drain plug washer from the factory? Maybe that's a bad example but it starts the thought process.
In the nine years I've been a member I've read many accounts here on FordBarn of owners believing that because something was on the car when they got it, it must have been on there from the moment it was built.
One real life example: I judged cars for originality/correctness at an event over ten years ago. A '35 Sedan owner, I'd guess about 70 years old who could trace the ownership of the vehicle from new within his family, had a lot of difficulty being told his steering wheel was not of the type that would have been on the car new. "Uncle would never have changed that." And "It's always been on there." Were his thoughts.
But I believe it's a physical impossibility for him to have knowledge of every incident in the time that passes from when the car was assembled to today.
Then again, the judges could have been wrong, or the car could have actually been assembled with pieces different than the typical example.
The bottom line is it's your car and to me that means you have every right to make it in a way that pleases you.
Adding: But Don Rogers and DavigG's information is literally good enough to bet the farm on. Those two have over 100 years combined experience with the vehicles. Each one has spent weeks researching the archives for the actual, factual, information.
-Jeff
Sorry I'm such a pill, but why not support the Early Ford V-8 Foundation Museum?
My avatar courtesy of 41ford1. Pic is him and Ol' Ron.
