05-13-2019, 04:04 PM | #1 |
Transmission case has casting # 48-7XX
Helping a friend buy a 1935 trans case for the larger V8. Found one w a casting # of 48-7XX on lower rear left next to tail shaft hole. Is that a correct case casting for the 1935?
Nomad |
05-13-2019, 04:51 PM | #2 |
Re: Transmission case has casting # 48-7XX
What is the LARGER v -8 motor? I may have a case for a 1935 or at least one that would be useable in a 1935 with a Ford flathead motor. kx
05-13-2019, 05:17 PM | #3 |
Yes, 48 prefix denotes 1935 introduction of part.
05-13-2019, 05:22 PM | #4 |
I have a ‘35 w a ‘39 Tranny & that case also has 48-7XX casting #. My eng is an 8BA. His is A 59A correct for a ‘35. He wants to use the correct casting # tranny case for a ‘35. I know all the 59A’s & 59BA’s can use the same config tranny case just want to make sure the 48-7XX is correct for the ‘35.
Nomad |
05-13-2019, 05:22 PM | #5 |
Thx Brian
Nomad |
05-13-2019, 06:32 PM | #6 | |
05-14-2019, 12:02 AM | #7 |
I wonder why having the trans being correct for a 35 is important when the engine clearly is not? Are you going to stamp the ViN from the trans into the frame?
05-14-2019, 08:54 AM | #8 |
The #48-xxxx transmission case was used in '35 & '36.
05-14-2019, 09:57 AM | #9 |
The sloped back shift tower fits the 1935 where it has to be modified to fit the later straight vertical tower from 1936 on up. I can see that as a reason.
05-14-2019, 12:06 PM | #10 | |
