Old 01-06-2020, 03:51 AM   #1
Lawrie
Lawrie's Avatar
Default oil pressure light
Any one know how you can turn on an oil pressure light using a racepac v300sd,
I cant seem to find it on their site
Thanks Lawrie
Lawrie is offline   Reply With Quote
Old 01-06-2020, 06:42 AM   #2
Fordestes
Default Re: oil pressure light
this space intentionally left blank
Last edited by Fordestes; 01-06-2020 at 10:43 AM. Reason: had a spammer,reported,no further comment
Fordestes is offline   Reply With Quote
Old 01-06-2020, 07:54 AM   #3
flatheadmurre
flatheadmurre's Avatar
In general you can take a look at the shiftlight function...analog rpm/set threshold/shiftlight on.....analog oilpressure/set threshold/light off.
Not sure how many output channels the unit have.
But you need the same programming as shiftlight except turn off at set level and same input/output channels.
Old 01-07-2020, 01:04 AM   #4
Lawrie
Lawrie's Avatar
Thanks, I tried to ring the help line but was waiting for ages,
I have emailed an enquiry so will see in a few days.
I have to wait now, as I just buggered the lithium battery we were using,it haf worked great until I cranked the motor for a while to get oil pressure, then started and ran it for 1/4 hr or so with the altinator not hooked up, the bat went flat and I cant recharge it,
a new bat is $600.
Lawrie
Old 01-07-2020, 11:19 AM   #5
flatheadmurre
Is it the intelligent charger that won´t charge the battery or does the battery pack has internal charging logics that says no ?
If you drain any "modern" battery below a threshold it says bad and won´t take charge...sometimes a "dumb" benchpower supply with a constant current limit can get it back into working order.
Real low amp charge or you need to keep an eye on it for temp !
Old 01-07-2020, 11:58 AM   #6
tubman
tubman's Avatar
For those of you as confused as I was about this thread, here's a little background information from the Holley web site : "V300SD data logger commonly used for Pro Stock, Pro Modified and many Sportsman classes. Comes with DataLink Standard software."
