Old 02-21-2020, 09:14 PM   #1
David R.
Default Hot water heat?
Any one done hot water heater on an A or AA as opposed to manifold type? If so, could you share some particulars? Where would you mount it, run hoses etc.,.?
David R. is offline   Reply With Quote
Old 02-22-2020, 10:03 AM   #2
Werner
Werner's Avatar
Default Re: Hot water heat?
Guten Tag David.
I did this on my 11 CV 10 years ago. It works very well. The continuous flow heater has 3000 watts. After 20 minutes I have a block temperature of + 40 - 50 ° C.
https://www.amazon.de/Elektrische-St...2383212&sr=8-5
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 02-22-2020, 10:45 AM   #3
The Master Cylinder
The Master Cylinder's Avatar
Originally Posted by Werner View Post
Guten Tag David.
What is that, a block heater? The only words I can read are 'Amazon' and 'Prime'. I think david was asking for a cab warmer using water instead of exhaust heat?
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is online now   Reply With Quote
Old 02-22-2020, 02:28 PM   #4
Werner
Werner's Avatar
Oh, I misunderstood that. I thought he meant a preheater for the cooling water in the cold engine block.
Werner
Citroen 11 CV, 1947
Old 02-22-2020, 04:43 PM   #5
Synchro909
Synchro909's Avatar
Manifold heaters can't be used on a RHD car but it still gets cold here. I'd be interested in a hot water system at reasonable cost. I say reasonable cost because we get a lot of hot air coming in around the pedals. The hot engine pipe is between the clutch and brake pedals (as is the accelerator) and there are always gaps. I still haven't seen a decent fitting mat for there. The hot air is nice during winter but makes driving an A an unpleasant experience during the summer.
Old 02-23-2020, 02:21 PM   #6
katy
katy's Avatar
Lots of old threads on this topic.
https://www.fordbarn.com/forum/showt...ghlight=Heater
https://www.fordbarn.com/forum/showt...8314&showall=1
https://www.fordbarn.com/forum/showt...ater&showall=1
Old 02-23-2020, 09:50 PM   #7
mleder
If someone can tell me how to post photos I can show you my installation of hot water heat I installed last year and very happy with it. By the way I use a Mac so if photo loading instructions are different let me know.
mleder is offline   Reply With Quote
Old 02-23-2020, 10:55 PM   #8
Russ B
The heater box is a 1937 Harrison adapted to a newer aftermarket heater.
I recall the upper and lower hose T’s came from Snyder’s and were already powder coated.
Russ B is offline   Reply With Quote
Old 02-23-2020, 11:55 PM   #9
Peyton
Vendors sell hot water heater installation kits (Bert's A-9426-K) $65 set. Used this for water hose hookup.
Found a F-150 heater core and Studebaker 6v blower--- connected the two with three inch flex alum tubing. Put the blower in the upper driver side firewall area and the heater core (with homemade plenum) on the passenger side kick panel. Connected the two with 3 inch aluminum flex tub routed between the gas tank and firewall. Not pretty but works well.
Hopefully, you will already have a hole in the firewall --- I would have done a floor heater had there not already been a hole in the passenger side of the firewall. Rigged a cheap switch for the blower.
My heater is crude but the car is definitely a driver but it is comfortable in cold weather. And I don't have to worry about carbon monoxide.
Peyton is offline   Reply With Quote
Old 02-24-2020, 05:29 AM   #10
Bruce of MN
Bruce of MN's Avatar
Russ, very tidy!
What is that finned item on the right side of the firewall?
Old 02-24-2020, 07:09 AM   #11
David R.
Originally Posted by peyton View Post
vendors sell hot water heater installation kits (bert's a-9426-k) $65 set. Used this for water hose hookup.
Found a f-150 heater core and studebaker 6v blower--- connected the two with three inch flex alum tubing. Put the blower in the upper driver side firewall area and the heater core (with homemade plenum) on the passenger side kick panel. Connected the two with 3 inch aluminum flex tub routed between the gas tank and firewall. Not pretty but works well.
Hopefully, you will already have a hole in the firewall --- i would have done a floor heater had there not already been a hole in the passenger side of the firewall. Rigged a cheap switch for the blower.
My heater is crude but the car is definitely a driver but it is comfortable in cold weather. And i don't have to worry about carbon monoxide.
pictures?
Old 02-24-2020, 07:14 AM   #12
David R.
Russ, thanks for the pictures. Looks like heater unit is central under gas tank, hoses come through firewall on driver's side? How did you connect the two? How do you control water valve? What kind of head and what is that finned tank for? Interested to hear how your modifications affect performance. Neat looking project.
Old 02-24-2020, 10:35 AM   #13
Peyton
Pictures
Old 02-24-2020, 12:03 PM   #14
katy
katy's Avatar
Russ, what is the gizmo in the heater return line, just below the 90° elbow? I suspect it is a control valve of some sort/
TIA, Ken
Old 02-24-2020, 12:05 PM   #15
Peyton
It's not perfect --- have to route hoses to firewall connections to get hot water to the heater core but we don't need heat often in Florida. However, when traveling to the Florida panhandle during the winter it helped to have some heat other than that from the engine.
Not to mention a great bypass system for engine cooling --- water circulation in the engine when the thermostat is completely closed.
Old 02-24-2020, 12:35 PM   #16
Russ B
Finned tank is a remote oil filter.
Old 02-24-2020, 12:36 PM   #17
Russ B
TIA, Ken
Yes. It is the heater control valve. It is vacuum controlled.
Old 02-25-2020, 02:08 PM   #18
bettlesr
bettlesr's Avatar
Here's a heater I put under the front seat in my Sport Coupe. My son welded up the box and we cut down a later pickup heater core to fit. The air comes out at about 175°F. The outlets are air vents from a British sports car. There is a third outlet on the box which dumps some warm air under the seat as a seat heater. The picture by the transmission shows the heater contol valve to change the temperature. It us from an old Chrysler vehicle.
1965 Lotus Elan S2
1930 Model A Sport Coupe
bettlesr is offline   Reply With Quote
Old 02-25-2020, 04:04 PM   #19
David R.
Bettlesr, thanks for sharing. What is the device in upper radiator hose?
Old 02-28-2020, 05:42 PM   #20
bettlesr
bettlesr's Avatar
That is an adjustable thermostat that was on my car when I bought it. It has since bit the dust.
1965 Lotus Elan S2
