12-26-2018, 05:55 AM | #1 |
Mounting a side mount spare to the chassis
I am putting another Model A together out of bits I have laying about and it will have a side mounted spare but I've never taken a close look at how the bracket is attached to the chassis. It almost looks as though it uses the same bolts as the engine mount to chassis but longer. There are no holes in the chassis already that look anything like close. Does anybody have a picture or even measurements and a description if the engine mounting bolts are not the ones please?
12-26-2018, 06:11 AM | #2 |
Re: Mounting a side mount spare to the chassis
To begin with, if your export version is the same as the US designed version, the mounting brackets are different between 28/29 and 30/31. Usually you will see three triangular shaped dimples in the frame rail(s) where the rivet holes should/will be drilled.
12-26-2018, 11:47 AM | #3 | |
Please review this article as it will point out the area for the side mount spare. http://www.plucks329s.org/pdf/frame/..._Assembly2.pdf The holes that go in the frame are 11/32". So we are on the right page and I do not type the wrong information...See page 249 and 508 in the Ford Service Bulletins. Pluck Last edited by Steve Plucker; 12-26-2018 at 11:55 AM. |
12-26-2018, 03:34 PM | #4 |
Sorry guys, I should have realised details of the chassis would be kinda useful. It is a 1928 chassis - one where the motor was bolted directly to the front X member. I think it is of Canadian origin and there are no dimples on it.
On reading Page 508 of he Service Bulletins (Glad I went to the trouble of getting one of those!), I note that the triangular plate that attaches to the wheel is verticle. There is no inclination as described so I guess it doesn't matter on which side I instal it. I will put it on th epassenger's side (Left). I think Page 249 of the bulletins will give me what I need, Thanks Steve.
I'm part of the only ever generation with an analogue childhood and a digital adulthood. Last edited by Synchro909; 12-26-2018 at 03:58 PM. |
12-26-2018, 07:51 PM | #5 |
I have a 1928 frame with solid motor mount that is drilled both sides and a 29 and a 30 with dimples . The 1928 looks just like page 249 of the service Bulletin . I can take a photo in the morning of the 28 if needed .
Dennis in Kelsey ca |
12-26-2018, 09:15 PM | #6 | |
I'm starting to sag now too. 38 degrees out there and rising. It's only a bit after 1 O'Clock now so by 5, it will be too hot for me. Glad to have that job out of the way.
12-26-2018, 10:14 PM | #7 |
It'll probably be easier to get a right hand guard with the well in it, as that is where it went on the utes.
12-26-2018, 11:31 PM | #8 | |
For our American friends slogging their way through winter, there were several places yesterday where the temperature topped 49C (120F).The sleigh needs a new raditator.
12-27-2018, 12:55 AM | #9 |
You need to relocate to charming Warrnambool, Synchro! We maxxed out in the low 30s at lunchtime today before a beautiful sea breeze kicked in.
12-27-2018, 01:34 AM | #10 |
I did have a matching pair of 29 welled guards years ago. So they must have been sold here as the "sports" version? Can't have been many tho.
