12-16-2018, 09:05 PM | #1 |
Possible Radiator Problem???
While driving my car to our annual September car show I have to drive up several hills.
I've driven this route many times with no problems. This day the car started "spitting" antifreeze out the radiator cap on 2 of the hills. Not a lot but enough to concern me. The 2 hills were about 5 miles apart. Drove home a different way, flat roads, no problem. Took the car out a week later and intentionally drove up several steep hills to see if the problem was still there. First hill was almost at the top and antifreeze started coming out the cap. The second hill was about 7 miles down the road and very steep from the start. NO problem-NO overflow. Car has 160 degree thermostat. Drained radiator today and removed thermostat. Plan to flush system later this week using a radiator flush. Looking for thoughts/suggestions. I plan to install new 160 'stat. Thanks….Bob |
12-16-2018, 09:18 PM | #2 |
Re: Possible Radiator Problem???
SO what did your infrared temperature scanner say? All four corners of the radiator?
12-16-2018, 09:18 PM | #3 |
47 years ago when I was a new bee, I would keep topping the radiator and it would sometimes overflow. When I let it seek its own level it quit overflowing. Also check the cap gasket, it should not leak there, it should come out of the overflow tube. You are adjusting the timing, retarding when climbing hills a little but not to much.
12-17-2018, 02:55 PM | #4 |
It has been my experience that Model A Ford Radiators find their own natural fluid level. Keep a monitor on your temp and before going on another test, do a fluid level check of the fluid in the upper tank. If there is about an inch or so, do not refill. Rerun your test. And Make sure the GAV is properly set and the advance is properly set. If it is still blowing out liquid, then I would start looking at the need to fix something.
12-17-2018, 04:55 PM | #5 |
I don't understand the statement leaking out of the radiator cap,they cap should be tightly sealed to the radiator,leak would be out the overflow to the ground.
12-17-2018, 05:39 PM | #6 |
Not saying this is your problem but it is a easy check.
The Master Cylinder Enjoying life at the beach in SoCal... |
12-17-2018, 06:08 PM | #7 |
Your radiator is plugged. It should flow at least 36 GPM.
12-17-2018, 06:32 PM | #8 |
If flushing - suggest initially flush/backflush motor and radiator separately with water, catch the water in a big tub so you can see what comes out. Then do same with whatever chemical method you were going to use chemical (thermocure, Rust 911, commercial, white vinegar, etc.), If using something acidic/aggressive, flush with baking soda mix to neutralize. Then install an upper hose coolant filter and run.
12-17-2018, 06:54 PM | #9 |
If you run it with some vinegar or anything designed to loosen up pieces of rust/gunk, you might want to RUN THE CAR WITH A FILTER IN PLACE. You don't want flushed rust/gunk to be circulating into the radiator only to clog something else up.
12-17-2018, 07:29 PM | #10 | |
My limited experience tends to agree with this. I just got a sedan that has a Motometer on it and I'm wondering how that is going to work unless the coolant level in the radiator stays within about an inch of the top. I haven't driven the car enough yet to know if it works at all. |
12-17-2018, 07:54 PM | #11 |
Car has motometer cap.
Fluid was just above the fins. The antifreeze was actually bubbling out around the cap. Going to flush system Friday, as temp is supposed to be 50. Cannot remember the exact infared temps but positive the upper radiator was in 170's to possibly low 180's. Lower temps 35-40 degrees cooler. I will change rad. cap gasket tomorrow. |
12-17-2018, 08:06 PM | #12 |
I would suggest checking the head torque if the flush doesn't work.
12-17-2018, 08:12 PM | #13 |
TMC: I will check torque.
Jackson:I don't think my rad. has ever come close to 36 gpm but it's run fine for the 6 years I've owned it. TJ: Coolant should be just covering the fins. Thanks to all the rest. Will advise what happens. |
12-17-2018, 08:15 PM | #14 |
DHZIEMAN: Where should the gav be set? Rich? Lean?
12-17-2018, 08:36 PM | #15 | |
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
12-17-2018, 08:41 PM | #16 |
I had similar problems and a new radiator didn't solve it. I finally put a clamp on the upper radiator hose so it the thermostat wouldn't work its way to the top, and let the level of the coolant fall a little. As long as it's above the tubes, should be fine. I think the thermostat at the top of the hose was creating too much turbulance.
12-17-2018, 09:16 PM | #17 |
If coolant is coming out from under the cap, the overflow must be blocked. That will not be the cause of your troubles but worth looking at (and correcting) anyway.
12-17-2018, 09:27 PM | #18 |
Worst case is head gasket is going, and only apparent when car is under load (hills).
Could try as mentioned re-torqueing Head, checking the overflow is open, flush backflush, run it and see if now OK. . Then compression/leak down, or Napa Block Test kit that measures exhaust gas in the coolant. Mechanic or radiator shop may also be able to test for the coolant test. Since you have had the car for awhile, I'm sure you know what is normal for your car, and something has changed. Would not think it would be GAV setting, coolant level, etc - seems you would already know that stuff. |
12-18-2018, 09:19 AM | #19 | |
What I discovered on my model A was, all nuts wound up needing re-torquing! |
12-23-2018, 11:42 AM | #20 |
Are gas caps the same size as radiator caps? Is it posible to put a gas cap on a radiator?
I was driving on a pretty warm day, up & down a few hills, when antifreeze came out from cap because temp was over 200*F. Stopped to let the car cool down & all was fine after. Gasket is good, but I was wondering if I had a vented gas cap on my radiator. |
