Old 07-30-2020, 09:24 AM   #1
masipopa
Default Oil leaks from around oil pan
I read that Model A's often leak oil, but I see pretty heavy dripping of oil somewhere from around oil pan and when I drive I see the trace from the oil drops. Would it be a good idea to remove oil pan and put a new oil pan gasket ? Does it typically solve the problem ? I intend to do it without taking the engine off the car.
Unfortunately I could not find a video on youtube showing the process. Are there any particular tips in replacing the gasket ?
Also if I remove the pan, is there any other maintenance worth doing at the same time ?
masipopa is offline   Reply With Quote
Old 07-30-2020, 09:52 AM   #2
jwilliams81
jwilliams81's Avatar
Default Re: Oil leaks from around oil pan
https://modelatouringclub.files.word...et-article.pdf
1931 Murray Town Sedan. Black body with Apple Green pin stripe.
1923 Model T Touring with electric start. Low radiator
Cincinnati, Ohio
jwilliams81 is offline   Reply With Quote
Old 07-30-2020, 09:54 AM   #3
katy
katy's Avatar
You could try tightening up the bolts that hold the pan on, might help, might not, it's worth a try. Don't over tighten them.
Old 07-30-2020, 10:08 AM   #4
jwilliams81
Yes, if you are reading and following the Les Andrew's red book... it says to torque the oil pan nuts to 20 ft lbs. That is wrong and a misprint.
You want to torque them to 5-6 ft lbs... but most just do tight with a wrench.
Torque values and capacities:
https://www.brattons.com/specifications.html
Cincinnati, Ohio
Old 07-30-2020, 10:29 AM   #5
30 Closed Cab PU
There are 4 oil pan bolts closest to the front of the car where the holes are not blind, go through to the motor oil. Perhaps try removing them and put sealant on the threads and reinstall. Maybe you will be lucky and that is you problem - happened to me.
Old 07-30-2020, 10:35 AM   #6
Ruth
Yes look around before dropping the pan. I thought I had an oil pan leak but it turned out to be the oil return pipe on the valve cover. Easy fix compared to dropping the pan.
If you decide to drop the pan, ensure the pan rail is straight before re-installation.
Ruth
Old 07-30-2020, 10:45 AM   #7
30 Closed Cab PU
The only other time I had a leak was my fault. First time I dropped the pan to service clean the oil pump screen, I used a new gasket set, and missed the instructions on not cutting the rope seal flush (allow extra length so it squashes in tight when pan is reinstalled), and did not add a dab of sealant on the pan next to the front/rear seals.
Old 07-30-2020, 01:51 PM   #8
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Wipe everything lean and run car to find the origin of the leak.
Old 07-30-2020, 04:05 PM   #9
1crosscut
1crosscut's Avatar
Yup... do this first. Could very well save you a lot of time and effort. Don't overlook the front motor mount bolts. One of them goes into the block and if the threads aren't sealed it can leak down onto the pan making it look like the pan is the culprit.
Buy a couple cans of aerosol brake cleaner go at it.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 07-30-2020, 04:14 PM   #10
Patrick L.
Patrick L.'s Avatar
Yep. I'm thinking the leak may well be something else.
Old 07-30-2020, 04:20 PM   #11
masipopa
Great advice. Do you use the aerosol break cleaner to clean the bottom of the pan ? It is all covered by oil deposits.
What about Fluorescent Leak Detection Dye to add to oil. Can it help to trace where the oil leaks ?
Old 07-30-2020, 05:06 PM   #12
Patrick L.
Patrick L.'s Avatar
You could use dye if you want, but, I don't think its necessary. There is enough room to look at everything.
Old 07-30-2020, 09:12 PM   #13
shew01
shew01's Avatar
I’ve never had my pan off, but, as I understand it, the pan holds the oil pump in the car. (Somebody will correct me if this is not right.) Remove the pan, and out pops the oil pump with it. The vendors sell a tool to help get the pump back into the car. The hole is easily stripped if you use the wrong type of screw in the hole.
https://www.snydersantiqueauto.com/P...earchByKeyword
Old 07-30-2020, 09:59 PM   #14
30 Closed Cab PU
Another tip if dropping the pan, drain the oil and let it sit overnight draining before removing the pan. Less drippage from the block area while the pan is off.
Old 07-30-2020, 10:39 PM   #15
1crosscut
1crosscut's Avatar
Yes go ahead and use it on the pan and engine. Works rather well for removing oil.
Old 07-31-2020, 04:32 AM   #16
shew01
shew01's Avatar
These can be used to help get the oil pan reinstalled.
Old 07-31-2020, 10:09 AM   #17
katy
katy's Avatar
The tool mentioned in post #13 is a good thing to use.
Another tip: bring #1 piston to TDC, then turn the crankshaft another 90°. This puts all the throws horizontal, giving more clearance for removing installing the oil pan.
Hopefully you'll find the leak and won't have to remove the pan.
