Old 02-18-2012, 07:30 PM   #1
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Ah Ha! I'm Brilliant!
No doubt, over the years you've come up with a trick or idea or a procedure that helped on your "A." You think, "Bet nobody ever thought of that!"
Time to 'fess up and share it! Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 02-18-2012, 08:00 PM   #2
BILL WILLIAMSON
Default Re: Ah Ha! I'm Brilliant!
Someone P.M'd Me, doesn't like this thread, called me a "SICK PUPPY!"?????????? bILL w. Well, I don't hOw tO TypE WeLL EitHer.
Old 02-18-2012, 08:02 PM   #3
Jim/GA
Jim/GA's Avatar
A 12 volt, 3 CP bulb installed in your instrument panel light on your original 6 volt model A will give you a nice dim, glowing light on your instruments that you won't mind leaving on while you drive at night. The stock 6 volt bulb is too bright.
Jim Cannon
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 02-18-2012, 08:18 PM   #4
VWJoe
VWJoe's Avatar
Well Bill, this might not apply to a model a since I have yet to find a phillips head screw on mine but have you ever had a phillips head screw that was boggered up in the cross and tight as the dickens ?? Try putting a dab of valve grinding compound on the tip of the phillips screw driver and screw that sucker out !!!
VWJoe is offline   Reply With Quote
Old 02-18-2012, 08:34 PM   #5
oljoe001
oljoe001's Avatar
I converted My Model a over to run on water!!! "sssshhhhh" Dont tell anyone I dont want the gas companies to find out. As I fear for my life. lol
oljoe001 is offline   Reply With Quote
Old 02-18-2012, 09:18 PM   #6
bobpo
bobpo's Avatar
O.K., I'll be quiet about it if you could elaborate.......
bobpo is offline   Reply With Quote
Old 02-18-2012, 09:41 PM   #7
oljoe001
oljoe001's Avatar
Well took plugs out and replaced with 1500 watt lasers inject water, fire the laser and instant steam wah lah a steam engine......... Sounds good huh....hey you had to ask lol
Old 02-19-2012, 12:07 AM   #8
Milton
Milton's Avatar
The equipment in front of the car is what you use to distill the water to run on?
Milton is offline   Reply With Quote
Old 02-19-2012, 12:23 AM   #9
BILL WILLIAMSON
VWJoe,
Great idea! That might even help on slot head screws to keep the blade from crawling out. For slot head screws, I hollow grind the tip of the blade so it has straight sides instead of wedge shape sides, helps quite a bit. Bill W.
Old 02-19-2012, 12:31 AM   #10
Leathernek
Leathernek's Avatar
I umm..... get on here and steal y'alls tricks!!!!!
Leathernek is offline   Reply With Quote
Old 02-19-2012, 12:46 AM   #11
BILL WILLIAMSON
We'll BILL you later! Credit card # please____________Or would you prefer to use Pay-Gal? Bill W. (my dog just laughed for the first time!) Life is good!
Old 02-19-2012, 01:12 AM   #12
Mike V. Florida
Mike V. Florida's Avatar
VWJoe,
A good set of gunsmith screw drivers have this "feature". I have seen some that are even a little hollow ground to help the tip move down into the screw.
Old 02-19-2012, 01:43 AM   #13
Roadster62
Roadster62's Avatar
Hood hinge rod removal with an electric drill works well. Lube up the hinge with your favorite penetrating oil let sit overnight. Tap the rod out an inch or so, attach the drill to it. Once you get it spin just put some pressure on it and it will pull out.
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical.
Roadster62 is offline   Reply With Quote
Old 02-19-2012, 02:07 AM   #14
Leathernek
Leathernek's Avatar
Credit Card #1234567890 !!!!!!! If it don't go through, just put it on my TAB!!!!! lol
Josh
Old 02-19-2012, 02:15 PM   #15
28RPU
28RPU's Avatar
Wish I could contribute but I'm dumb as a rock.
Donít pick a fight with an old man. If he is too old to fight, heíll just kill you.
28RPU is offline   Reply With Quote
Old 02-19-2012, 02:30 PM   #16
al's28/33
al's28/33's Avatar
I have a 2 year old daughter who is running all around, putting her hands on everything........so to protect my "A" I have walled off half the garage using an old refridgerator box.
No more sticky fingerprints on shiny black fenders!!!
Old 02-19-2012, 07:05 PM   #17
BILL WILLIAMSON
Cut an old coil wire in half, peel of 1" of insulation on each end, insert each end through 2 opposing holes in a small button, twist them tightly & neatly, & Voille,' you have a built in, hands free, spark testing GIZMO!!
Another trick, to test your coil tower for high voltage leak, in the dark, coil wire out, key on, crank it and look for spark jumping out of coil tower to primary terminals or coil case. Bill W.
(There's 1 Barner that thinks I NEVER contribute usefull info. So how about that, DUDE.)
Old 02-19-2012, 08:47 PM   #18
columbiA
If you want to check the spark at the plugs,hold a flourescent tube near a plug wire & it will flash every time a plug fires.Even a burnt-out one will do.
columbiA is offline   Reply With Quote
Old 02-19-2012, 09:26 PM   #19
garrisonm89@yahoo.com
I have my neighbors redheaded stepson hold on to the plug wires while I crank it over. His hair's standing on end more and more each day so we're using him as a crossing guard now. He's always been ugly enough to stop traffic and now he can really get their attention. It's really fun now because his eyes have crossed and the spark is actually bridging across the bridge of his nose. I've made $18.75 charging other neighbors 2 bits a piece to come in the garage and watch the show. Now the other day I notice a fat 300 lb bearded lady down at the other end of the park and I'm sure with some modifications I'll be able to get a few bucks more by adding on to the show.
It's 110 miles to Chicago
We've got half a pack of cigarettes
It's dark
And we're wearing sunglasses
Let's go.
garrisonm89@yahoo.com is offline   Reply With Quote
Old 02-22-2012, 03:51 AM   #20
BILL WILLIAMSON
A friend's idea,when fitting those +*&$%#@^ fussy fender and bodywelts, secure them in place with peel off self sticky velcro patches, they can be repositioned if necessary and they also make up extra thickness for those areas that might not grip it tightly. I had a loose one, an I put some Gorilla Glue in a hypo needle, injected it in the crack and taped it down 'til it dried.
For that dried white wax in hidden cracks, push drier lint into a soft toohbrush, dip it in water, scrub crack, wipe with damp cloth, and it looks perfect! I also amused Pat by making stick on mustaches from the lint.
How to know if you'r old, whatever color you tee shirt is, your belly button lint is always GREY! Try it!! Bill W. (I fired the Ghost!!)
Thread Tools
Display Modes
