Old 05-19-2010, 01:02 PM   #1
wamnram
wamnram's Avatar
Default Transmission Failure due to new oil
I was reading the earlier posts on type of oil to use in the transmission based on incompatability with the bronze/brass material. (140wt GL-4/5). Iv'e never really paid attention to the 90-140 wt oil I have used in the past and have never had any problems, then again I don't put on many miles either. Has anyone ever had a failure due to the wrong type of oil in their transmission? (abusing your transmission and blaming the oil doesn't count!)
Just wonderin'
Wayne/Texas
Wayne
wamnram is offline   Reply With Quote
Old 05-19-2010, 01:08 PM   #2
Cecil/WV
Cecil/WV's Avatar
Default Re: Transmission Failure due to new oil
Nope!
Cecil/WV is offline   Reply With Quote
Old 05-19-2010, 01:15 PM   #3
jdl
jdl's Avatar
Send a message via ICQ to jdl
Lots of miles with no problems...
Jim
jdl is offline   Reply With Quote
Old 05-19-2010, 01:40 PM   #4
Bruce Lancaster
There has been endless discussion about the stuff that attacks brass...I eventually found an article on it. probably from a link here, that sounded pretty authoritative in its source and stated that the problems began at something like 350-400 degrees. I decided to quit worrying about this.
Old 05-19-2010, 03:09 PM   #5
Bassman/NZ
Bassman/NZ's Avatar
Worrying about what?
Bassman/NZ is offline   Reply With Quote
Old 05-19-2010, 03:57 PM   #6
Bruce Lancaster
Actually, I forget, but I'm going to get on with the necessary worrying about the phase-out of leaded gasoline. Folks, once they finish phasing out the lead, our valves are all going to fail immediately, and by 1980 we won't have any old Ford left!
Old 05-19-2010, 04:08 PM   #7
Ole Don
Ole Don's Avatar
I bought one of the Tremec T3550 five speeds when they came out. I used ATF in it. After a few years, it developed a whine when backing down in second. I called the fellow who sold me the trans, the first thing he asked was what oil was in it. I told him, he said get it out and put in GM Sychromesh oil. I did, no more noise. Magic oil, but at 11 bucks a quart it should be.
Ole Don is offline   Reply With Quote
Old 05-19-2010, 04:14 PM   #8
40 Deluxe
Also, don't forget to worry about the reduced zinc additive in new oils. It still has a lot more than oil fo the '30's and 40's, maybe even '50's, had, but suddenly it's a problem! Just think about all the flatheads and Model A's, etc. that ran for years with re-refined and/or non-detergent oil! Think that stuff had any zinc additive in it? Nope!
Old 05-19-2010, 04:30 PM   #9
wamnram
wamnram's Avatar
Thanks yall! I was just wonderin because I have never heard of a tranny failure due to this.
Wayne
