Old 08-17-2019, 05:53 AM   #1
37 Cab
37 Cab's Avatar
Default Got the call
I got a call from Mitchell yesterday letting me know my overdrive is finished and shipping. I am looking forward to getting it in soon. My first question is, Will it be Ok to leave my rear tires on and remove the rear end with spring attached? I have never removed a banjo so this will be a first. I have a two post lift. I take it both halves of clamshell need to come off? Any pointers?
Tommy
37 Cab is offline   Reply With Quote
Old 08-17-2019, 06:34 AM   #2
36rgtop
36rgtop's Avatar
Default Re: Got the call
Have removed and installed tranny's using only bumper jacks and jack stands (to lift and hold body) just high enough to roll the whole rear assy. on wheels far enough back to give access to tranny removal.
Of course all attachments to tranny have to be disconnected.
36rgtop is offline   Reply With Quote
Old 08-17-2019, 07:35 AM   #3
Pat/Ohio
Pat/Ohio's Avatar
Tommy, When I pulled the rear from my '40 Conv. a few years ago...I made two round wooden wheels out of OSB. It gave more clearance to slide the rear out without scratching anything. Good luck, Pat
Pat/Ohio is offline   Reply With Quote
Old 08-17-2019, 07:36 AM   #4
Old Redneck
Old Redneck's Avatar
Send a message via AIM to Old Redneck Send a message via Yahoo to Old Redneck
You need Jack stands and a floor jack to remove the rear end. That how I do it. Just slide the rear end back enough to remove the driveshaft.
Old Redneck is offline   Reply With Quote
Old 08-17-2019, 07:43 AM   #5
Pat/Ohio
Pat/Ohio's Avatar
Ken, I should have stated that I removed the rear from my/your '40 Conv. while it was on my 4-post lift. Fun!
Old 08-17-2019, 08:26 AM   #6
Ol' Ron
Ol' Ron's Avatar
Get help, from some one that'd done it before. Good luck
Old 08-17-2019, 08:45 AM   #7
Planojc
Planojc's Avatar
Yes you can leave the tires on, just get it high enough to roll it out. Then remove the torque tube and drive shaft and replace with the Mitchell. You will love it.
Planojc is offline   Reply With Quote
Old 08-18-2019, 04:08 PM   #8
Kerk
Just a word of Caution. Be sure that when you remove the Heavy read end assembly thatb= you have enough support for the front rest of the car as on a 2 post lift it could fall down in front with a plan or support for what will be the HEAVY front end of car! Just a word of caution... Good luck. kx
Kerk is offline   Reply With Quote
Old 08-18-2019, 05:39 PM   #9
37 Cab
37 Cab's Avatar
Thanks Kerk.. I will be sure to lift the car with the rear heavy and keep an eye on it. I am excited to get this done. Up to this point I have not been comfortable taking my car over 20-30 miles from home just because I can`t maintain highway speeds without worry of hurting it due to RPMs.
I appreciate all the helpful comments... I have no help so it is going to be just me.
Tommy
Old 08-18-2019, 06:21 PM   #10
Charlie ny
Cab,
Using jack stands and a floor jack I perfer to remove the tires and wheels and roll the rearend out on the drums.........the car does not have to be lifted as far.
Charlie ny
Charlie ny is offline   Reply With Quote
Old 08-19-2019, 01:38 PM   #11
oldford2
oldford2's Avatar
That's what I did when I installed mine. Take the tires off. What shift did you get? Cable or lever. Also don't forget clearance once installed. What year is your car? A lever would not work on a 46 so I used the cable which works great. You will love it.
John
oldford2 is offline   Reply With Quote
Old 08-19-2019, 02:00 PM   #12
51 MERC-CT
51 MERC-CT's Avatar
Originally Posted by Charlie ny View Post
Cab,
Charlie ny
Some of us need the extra room (girth-wise)
Old 08-19-2019, 07:38 PM   #13
37 Cab
37 Cab's Avatar
John
I went with lever. My car has reversed springs so I kind of expect clearance issues. Steve at Mitchell didn`t think so, but we shall see. The reason I ask about the wheels is because a previous owner used the 37 hubcaps on 15" wheels. I don`t think I can get them off without destroying them. I know it is a job I have to look forward to just don`t want to get into that right now.
Tommy
