Old 04-17-2019, 04:49 PM   #1
mrtexas
mrtexas's Avatar
Default Turn signals
Here is the turn signal switch I like from http://turnswitch.com/Turnsignal.htm. It cancels by time and the timer extends while your foot is on the brake. Has an emergency flasher feature. Uses stock wiring harness and only a few additional wires required(beyond the 12v to the unit), one parking light, one rear stop light, one to headlight switch, one brake light switch. I have it on both my 36 and just installing it on my 41.
Palindromes:
Do geese see God?
Was it a car or a cat I saw?
Won't Neil call a Walla Walla client now?
Dr. Gong! Get ale to my motel at Egg-nog Rd!
41 woodie https://41fordwoodie.weebly.com/
mrtexas is offline   Reply With Quote
Old 04-17-2019, 10:56 PM   #2
Flathead Fever
Flathead Fever's Avatar
Default Re: Turn signals
I grew up in the back of a Model A in the 1960s. This is the turn signal switch I remember everybody in the Model A Club using. I'm not sure anybody would know what it means anymore?
Flathead Fever is offline   Reply With Quote
Old 04-18-2019, 07:38 AM   #3
john in illinois
john in illinois's Avatar
I have the electro-tec system in my hotrod. I use a momentary contact switch under the dash. Works well.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 04-18-2019, 10:23 AM   #4
Drbrown
Drbrown's Avatar
Off-subject but mentioned above; Re Hand Signals .... remember taking my driver's test in 1954. Had to know your out-the-window hand-turn and even the stopping signal to pass the driver's test. Some cars came with steering column directionals (an extra cost on new cars ?) Not so much fun in winter weather.
Drbrown is offline   Reply With Quote
Old 04-18-2019, 10:55 AM   #5
bosborn38pu
bosborn38pu's Avatar
I used Turnswitch also. Like the features and pretty straightforward installation.
bosborn38pu is offline   Reply With Quote
Old 04-18-2019, 11:25 AM   #6
5851a
They need to bring back the old tests, you can add throwing your arms up in the air at round abouts.
5851a is offline   Reply With Quote
Old 04-18-2019, 03:17 PM   #7
Bursonaw
Bursonaw's Avatar
Great switch. I have installed the same system on both my cars.
Sent from my iPad using Tapatalk
Bursonaw is offline   Reply With Quote
Old 04-18-2019, 03:53 PM   #8
Ken/Alabama
Ken/Alabama's Avatar
That's the turn signal I use. Most people just wave back. I'm not a fan of turn signals on my early Fords.However my 40 convertible does have them but the tailights and park lights are small and they can't be seen anyway eventhough it has a 12 volt system and halogen bulbs. I never thought it was worth the effort to install them.
Ken/Alabama is offline   Reply With Quote
Old 04-18-2019, 05:31 PM   #9
Graeme / New Zealand
Graeme / New Zealand's Avatar
Installed signal stat unit on my 48 last year. Made my own loom. dual filliment conversion from C&G in the front park lights, converted 2 Ford Hall back up lights with orange bulbs and cut a clear orange kitchen spray bottle up and placed behind the bulb for extra spread. You can hardly see it when not operating. Best thing I ever did, it was embarrasing turning corners with no blinkers before and as for hand signals some people thought you were either waving or making "rude signs"
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Thread Tools
Display Modes
