Old 04-09-2019, 08:56 PM   #1
Lawson Cox
Lawson Cox's Avatar
Default White vinegar as radiator flush
What are the do's and don'ts of flushing radiator with white vinegar. Also, what's the best rust preventer after flush. Thanks guys.
Old 04-09-2019, 09:58 PM   #2
M2M
M2M's Avatar
Default Re: White vinegar as radiator flush
I've just done this with my model A. Vinegar sold in the USA is weak at only 5 or 6 % strength. I poured it into a non-running car and left it in there for almost three days. Then flushed the system with baking soda mixed with water to neutralize any acidity. Then flushed a few more times with simple green.
M2M is offline   Reply With Quote
Old 04-10-2019, 07:32 AM   #3
alanwoodieman
put in vinegar, run thru a least three cold hot cycles and then flush out with water and then add baking soda water mixture and run to temp and flush while it is running, you will not believe how much crud comes out
Old 04-10-2019, 08:46 AM   #4
32phil
Just curious.....has anyone tried Evaporust as a radiator flush ?
It does a great job cold but it really works well/quickly hot.
Early Ford Lock & Key Service
https://www.fordbarn.com/forum/showthread.php?t=46583
32phil is offline   Reply With Quote
Old 04-10-2019, 09:17 AM   #5
tubman
tubman's Avatar
I have used "Rust 911", which which works like Evaporust, but is a little cheaper. I thought the results were very good. I filled the system with it, ran three heat and cool cycles, and then drained and flushed it. I did this twice. Check out post #8 in this thread for pictures : https://www.fordbarn.com/forum/showt...light=rust+911
A poster named "Old Henry" (or maybe that was what he called his car) did a pretty detailed thread in which he did a cleanup on his water pumps. The results were pretty impressive. Look at post #30 on this thread : https://www.fordbarn.com/forum/showt...aporust&page=2
Old 04-10-2019, 09:31 AM   #6
texas webb
Pickling vinegar is 9 percent and works well.The flush is important.
texas webb is offline   Reply With Quote
Old 04-10-2019, 10:25 AM   #7
JM 35 Sedan
JM 35 Sedan's Avatar
Exactly what I did on my 35 Fordor (avatar) several years ago. I could not believe what came out. Neutralizing acidic mix with baking soda is an important step after flush.
John
Old 04-10-2019, 10:56 AM   #8
philipswanson
Put two cups of straight phosphoric acid in it, then flush with backing soda after a couple of hundred miles. Repeat as necessary. You might have to do this several times in a really bad system. If you have a clogged radiator, reverse flush or rod out.
philipswanson is offline   Reply With Quote
Old 04-10-2019, 12:55 PM   #9
jrhaelig
jrhaelig's Avatar
Just be mindful of the other crud that may come loose.
I flushed the radiator on my '39 Buick with vinegar, then the soap from a dishwasher gel pack (they are all super-low sudsing).
Anyway - busted loose all kinds of crud in the block - that subsequently clogged my radiator!
The old stocking filter on the inlet pipe might have prevented the removal and professional cleaning that followed.
Good luck!
John Haelig
Bridgewater, NJ
1939 Ford Pickup
1963 Lincoln Continental
1939 Buick
jrhaelig is offline   Reply With Quote
Old 04-10-2019, 01:02 PM   #10
1931 flamingo
1931 flamingo's Avatar
After doing the vinegar trick do NOT drain and flush on a concrete drive way...FWIW.
Paul in CT
Old 04-10-2019, 03:33 PM   #11
Drbrown
Drbrown's Avatar
Just a point of reference, couple years back Old Henry posted a thread here about his testing of cooling system flushing components, including vinegar. I believe he found vinegar (don't know what strength) to have a short-active-life, at least effect compared to Evaporust and/or others.
Might be worthwhile to find what he had to say.
Drbrown is offline   Reply With Quote
Old 04-10-2019, 05:08 PM   #12
v8nut
v8nut's Avatar
I would recommend using a product available from Harbor Freight called Rust 911. It is a colorless odorless concentrate that you dilute with water for use. It may be similar to Evaporust . Use as directed. I think you will find it more effective than vinegar. I used it to lean up a radiator that was completely blocked with rust and scale. Jim in San Jose.
v8nut is offline   Reply With Quote
Old 04-10-2019, 06:48 PM   #13
tubman
tubman's Avatar
I use "Rust-911" when I have large pieces. It works the same as "Evaporust", but from my experience, not quite as well. I think it is because it is a concentrate.
I would recommend those of you that are recommending vinegar review the "Old Henry" Thread mentioned in my earlier post (and one other). It is an acid and can damage cast iron and steel if used too long. Be very careful with it.
Old 04-10-2019, 07:59 PM   #14
adileo
adileo's Avatar
My 39 always had an issue running hot at at (on most summer days) 210. This is with 170 stats. Didn’t matter whether I was doing city driving or highway.
I pulled it over the winter and brought it to a radiator shop. He cleaned it chemically and then pressure tested it. Cost was best $80 bucks I spent in a long time. Car runs at a constant 170.
I should also mention, I think this is original radiator with the split down middle.
Thanks
Andy
1939 Deluxe coupe
1952 F1
adileo is offline   Reply With Quote
Old 04-10-2019, 08:08 PM   #15
woofa.express
woofa.express's Avatar
I used strait vinegar into a new radiator to clean out the block in my Model A. The new radiator had a flaw and leaked where the upper neck is soldered to the top tank. What a mess in the engine compartment and onto my slick paint job.
I also found vinegar must be followed by baking soda to get a clean radiator and block.
I know many things,
But I don't know everything,
Sometimes I forget things.
And there are times when I have a long memory.
woofa.express is offline   Reply With Quote
Old 04-10-2019, 09:13 PM   #16
VeryTangled
VeryTangled's Avatar
Yes I personally have, sorta. Using the similar product Rust-911, I was satisfied. Except for the volume of waste fluids it did what I wanted. 5 Gal of de-rust mix, and twice 5 gal of flush, so a lot of liquids to recycle.
My eventual solution was a recored radiator, but that was not the reason Rust-911 didn't solve the issue. I did an engine swap and lucked into a super fresh rad to exchange in at the same time as the powerplant.
And if any of you readers somehow have not had it register yet. Check out what Craig/Old Henry documented. He laid out a very good case! His deal is doing that against the Gummint' for us wronged citizens. So realize he's arguing a viewpoint. You can/should judge if it's the correct argument for your situation. A good guy and I miss his contributions. Hope he hasn't trashed too many aero-vehicles. Lord knows I've broken a few in my younger days.
-Jeff
Old 04-10-2019, 10:06 PM   #17
cas3
an old radiator man told me once, never put acid in a radiator as it will attack the solder first. just sayin
Old 04-10-2019, 10:27 PM   #18
woofa.express
I wonder if that is why the solder joint failed on my A. It was a pressurized (4 pound) radiator and nearly new. it was straight vinegar.
I know many things,
Old 04-10-2019, 11:06 PM   #19
Tinker
Tinker's Avatar
Model A radiators were never pressurized. I wouldn't leave vinegar in for a long time, but it's really a very very mild acid. It'd take a long time to eat away on any type of metal. In my opinion.
Something like rust911 would probably be best. chelate. It's somewhat a citric acid based. You can buy citric acid in bulk and mix it to whatever percent you like.
https://www.amazon.com/Milliard-Citr...ECZRBW2D7ZW17F
https://www.garagejournal.com/forum/...ad.php?t=69793
Old 04-11-2019, 06:31 AM   #20
tubman
tubman's Avatar
To be perfectly clear, "Rust-911" and "Evaporust", while "Chelates" are NOT citric acid based. I mixed up a batch of citric acid and tested it with pH test strips. it tested out as quite acidic. When I checked "Evaporust" the same way, it tested absolutely neutral. It's time to put this one to rest.
