11-03-2012, 11:18 AM | #1 |
29 Model A Rumble Seat Back Cushion
Would appreciate any info how 29 Roadster rumble seat back cushion should be/can be fastened to rumble seat lid. When I close my rumble seat the back cushion often comes loose from the lid. It has brackets on the seat frame than hang over lid rods. However, it's not secure. How can I get this back seat cushion to stay fastened to rumble seat lid when opening & closing.
11-03-2012, 11:26 AM | #2 |
Re: 29 Model A Rumble Seat Back Cushion
Take the cushion out, on the bottom edge there should be two wire clips that need turned down to allow you to install fasteners thru holes in the lid. Can post pic later if that helps.
11-03-2012, 11:27 AM | #3 |
Oh, the top solid bracket slips into slots at the top of the lid.
11-03-2012, 12:43 PM | #4 |
Thanks Steve. Pic would help if you have time. My top brackets are currently loose from the lid so the seat back flops forward slightly when I lower lid. However, bottom of the seat back seems fastened to something. Didn't try to remove entirely until I know a little more.
11-03-2012, 01:48 PM | #5 |
Below: Reshaping a slot that has never been used. Lower tabs mount here. Originally used #12-24 screws.
http://www.abarnyard.com/ |
08-18-2021, 08:38 PM | #6 |
Jimmy Palmer |
08-18-2021, 08:41 PM | #7 |
/Users/jamespalmer/Pictures/Photos Library.photoslibrary/resources/proxies/derivatives/1d/00/1d9a/UNADJUSTEDNONRAW_thumb_1d9a.jpg
I also put another screw in the bottom bracket slot so it could not come up
Jimmy Palmer |
