Old 06-29-2019, 06:09 PM   #1
Chris Haynes
Chris Haynes's Avatar
Default Evapo-rust gel
Has anyone tried it? How does it work?
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 06-29-2019, 06:20 PM   #2
Colonel
Default Re: Evapo-rust gel
I have used it numerous times trying to clean the water side of an A engine in place. Difficult to tell if it made much difference. I think others have had more positive outcomes.
Colonel is offline   Reply With Quote
Old 06-30-2019, 11:49 AM   #3
30 Closed Cab PU
Was a long time ago, looked at the gel on line, read reviews. I think I saw where the stuff is so thick it can be difficult to work with. You can check the reviews, see what you find.
30 Closed Cab PU is offline   Reply With Quote
Old 06-30-2019, 04:32 PM   #4
Chris Haynes
In the past I have used the Citrus based gel from Resteco. When I called to order it that have discontinued it.
For the past couple of years I have been immersing parts in Rust911 liquid. It works wonderful. I even used it to clean my cooling system. But as a water consistency liquid it isn't good for body parts. So I need a gel. Rust 911 doesn't have one so Evapo-rust is my only choice. I'll let ya know how it works out.
Here is my rusty project.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 06-30-2019, 08:37 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
I would get the sandblaster out and go to work.
Years ago I tried Naval Jelly, and had no luck with it.
Old 06-30-2019, 10:12 PM   #6
eagle
eagle's Avatar
As Tom W stated, sandblaster will do great things for that project. Keep air pressure low and keep moving. The roughened surface will hold the primer sealer really well too.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
