10-16-2018, 11:20 PM | #21 |
Re: Greetings from New Zealand.
Good on you mate!
Visited your country 2004 or 5, very agreeable time. |
10-17-2018, 12:46 AM | #22 | |
Here's a you tube clip for the pronunciation https://www.youtube.com/watch?v=mdJupnWKykE |
10-17-2018, 11:54 AM | #23 | |
That is a '57 and later Y-block distributor which has vacuum and mechanical advance. It will not operate properly with the original carburetor unless there has been some modifications. There are some folks in here you can give you more detail about that. If the intake manifold and carburetor on your engine have been swapped with a '57 or later Y-block and everything is properly connected, you are probably good to go. |
10-17-2018, 12:56 PM | #24 | |
At this stage I just need it to run so I can move it about to get further body work done. Once that's completed I'll circle back and sort this carb out properly. It's sure is an interesting design and pretty compact for what it's designed to achieve. |
10-17-2018, 06:32 PM | #25 |
"Interesting" is a good description for a Holley 4000 teapot.
Sal |
10-19-2018, 12:05 AM | #26 |
10-19-2018, 07:55 AM | #27 |
Good deal. Thanks for posting that.
Sal |
